my 2.0 idles out of control, pls see pic and give suggestions |
jimkelly |
Apr 21 2007, 09:55 AM
thanks jim
http://www.pbase.com/jimkelly/image/77494098/original.jpg what is compnent dangling just under coil in pic with vaccum line connected to it?? note i appear to have vaccum advance and vaccum retard vaccums lines |
pbanders |
Apr 21 2007, 10:10 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
That's your decel valve. You also don't appear to have a flashback trap or hoses from your head vents (normal on a '75?).
Allan |
Apr 21 2007, 10:19 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Check the ports on the throttle body. On my '75, one of them was a dummy port and IIRC it was the one you have the vacuum advance tied into.
SLITS |
Apr 21 2007, 10:22 AM
No head vents on '75 - '76.
The Throttle Body is that of a '73 (dual vac pipes for advance/retard). '74 up has a single vac tap. |
Cap'n Krusty |
Apr 21 2007, 11:30 AM
What's with all the water hoses? Is this some trick hybrid cooled secret project ... ?
The Cap'n |
jimkelly |
Apr 21 2007, 11:50 AM
ok - found the main problem - one fat port on the plenum had no hose to it nor was it plugged - i plugged it and engine now runs fine - took it on a food shopping run with my son - he was impressed that this car has paint and an interior : ))))
also i removed decel valve. more pics of drivers side port hole and passenger side port hole and decel valve before removal. see my blog thanks guys |
jasons |
Apr 21 2007, 12:42 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
What's with all the water hoses? Is this some trick hybrid cooled secret project ... ? The Cap'n (IMG:style_emoticons/default/chairfall.gif) The good Cap'n made a joke! I've seen hoses like that collapse on themselves under vacuum. |
jimkelly |
Apr 21 2007, 12:49 PM
finding the right ID hose at flaps is hell - guess i will just get full set at pelican parts ??
jim |
John |
Apr 21 2007, 10:11 PM
I wouldn't remove the decel valve if I was you.
Lo-Fi Version | Time is now: 27th September 2024 - 06:40 AM |
