Pre-induction system install question, 3-prong electrical fitting? |
mstein95 |
May 6 2007, 04:37 PM
Back when grey Levi's were the rage. Group: Members Posts: 404 Joined: 1-May 06 From: Eugene, OR Member No.: 5,959 Region Association: Pacific Northwest |
Keep in mind - newby rebuild.
Just about to install stock D-Jet fuel injection system onto fresh rebuild when I read a sentence out of Tom Wilson's How to Rebuild Your Volkswagen Air-cooled Engine: "on fuel-injection engines, there is an electrical-ground fitting that mounts under the head of one of the case bolts. This fitting has three spades for electrical connectors. If you install the intake manifold without this piee in place, it's nearly impossible to install it with the injection in place." I pause, swear, and wonder what the bleep Tom is refering to. (IMG:style_emoticons/default/WTF.gif) I've looked through the Haynes manual and don't see any reference to this fitting. My questions: 1) Do I need this fitting for the D-jet set up? 2) Does anyone have a picture of this fitting? Installed? 3) Where might I source this fitting? Thanks |
Cap'n Krusty |
May 6 2007, 05:31 PM
It's a washer with 3 male push-on connector tabs sticking out over about 180 degrees. They're all bent outward from the plane of the washer as installed. It goes on the 2nd top case bolt from the flywheel end of the case, on the #3 side. It has to be there to provide grounds for the injectors and other stuff. The Cap'n
mstein95 |
May 6 2007, 10:27 PM
Thanks Cap'n. I going to check my local sources (Rhodyguy, DNHunt) for this item.
Thanks Dave (DNHunt) for the quick response and for the washer/fitting. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:49 AM |
