OT: Great Plumbing/Fittings Source, Supplier caters to Plastics Industry |
Brian Mifsud |
Aug 31 2007, 11:26 AM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
I found a great source for hose and hose fittings as well as pipe fittings you all may want to tap into for your 914 and various mechanical projects.
Plastics Process Equipment has 3 strategic locations nationwide. Pricing is very very good and the quality of the parts are excellent. Plastic Process Equipment They feature Parker hose and associated fittings up to 1". Fuel rated, and or high temperature silicone hose. I've bought every fitting/hose I needed for the fuel and cooling arrangement for my diesel engine installation in my boat. They also have the following materials that can be used in Porsches: Silicone Dryer Hose, 1 1/4" to 8" diameters, rated to 550F All Stainless Steel (including Screw) Hose Clamps 7/16" to 9 3/8" Oetiker Hose Clamps (OEM on Fuel Lines??) You V-8 conversion guys should check them out since there are a huge number of useful parts on their site. |
Lo-Fi Version | Time is now: 26th September 2024 - 09:51 PM |
