Electrical short, Right turn signal |
TomL |
Nov 9 2007, 09:48 PM
Newbie Group: Members Posts: 13 Joined: 10-October 04 From: Lubbock, TX Member No.: 2,916 |
Right turn signal and hazard blows the fuse every time.
Specifics: Ignition OFF: parking lights all work; turn sig lever right-right parking/running lights come on; same thing left. Shouldn't do this with the ignition off--huh? Ignition ON; Turn signal left works fine; turn signal right blows fuse; hazard light switch ON blows fuse. Year model '74. I've spent a lot of time chasing wires and sorting as per wiring diagram. I probably have a wire crossed somewhere. A lot of you have a lot more experience than I do--any suggestions would be appreciated. Thanks! Tom |
Hammy |
Nov 10 2007, 09:58 AM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
Right turn signal and hazard blows the fuse every time. Specifics: Ignition OFF: parking lights all work; turn sig lever right-right parking/running lights come on; same thing left. Shouldn't do this with the ignition off--huh? Ignition ON; Turn signal left works fine; turn signal right blows fuse; hazard light switch ON blows fuse. Year model '74. I've spent a lot of time chasing wires and sorting as per wiring diagram. I probably have a wire crossed somewhere. A lot of you have a lot more experience than I do--any suggestions would be appreciated. Thanks! Tom The ignition off part is correct. It's a parking thing in Europe (or just Germany?). For parking on the street. Can't help much with the other problems. The obvious thing to do first is check your grounds. There's a grounding stud behind each headlight bucket. Also under the dash to the left of the fuse panel. Check for any loose wires on the fuse panel.... I'm sure the others will have a more specific answer. |
Cap'n Krusty |
Nov 10 2007, 10:38 AM
Sounds like wires mixed up in the rt turn signal/park light assembly. The Cap'n
Spoke |
Nov 10 2007, 02:20 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Have you done any work on the car lately? May have bumped something. Check there first.
To chase your short: 1) disconnect battery. 2) Put your voltmeter on resistance and connect from load side of fuse to ground. If you have a short, it should be noticeable now. 3) Remove front, then rear signal bulbs. Check for change in resistance. You're looking for the resistance to go from a few ohms to greater than 5-10 ohms. Once you find the short, the voltmeter will read more resistance than when you started. Keep in mind that the resistance of the bulbs will only be a few ohms so the difference between a short and correct operation may only be a few ohms. Spoke |
Lo-Fi Version | Time is now: 27th September 2024 - 12:35 PM |
