PUSH ROD TUBE SEALS, 73 1.7 |
Ray Warren |
Jan 19 2004, 07:23 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
i'm not sure what O rings i need.
i know one end has 8 black but the other end could be red or green according to the pet cd. engine is a 73 1.7 also, i read the tech article on 914fan.net about doing this job while the engine is in the car. has anyone done this? |
TheCabinetmaker |
Jan 19 2004, 07:28 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
yes, it can be done in the car. Not sure about the color.
trojanhorsepower |
Jan 19 2004, 07:37 PM
Senior Member Group: Members Posts: 866 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
I did mine with the motor out. The top ones are green, but I don’t know if they are considered to be the best. Do a search for “pushrod tubes” and see what Jake and Brad say. I think it is something like Vitron? "V" something any way. Jake gives a good explanation in that thread. I will try to find it and post something useful.
-Pete |
415PB |
Jan 19 2004, 08:01 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
The top ones should be green. I did mine while the engine was in the car, it was actually pretty easy.
Matt Romanowski |
Jan 19 2004, 08:12 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Hello,
The green ones are viton and are usually considered to be the best. They seem to last the longest, although they all work. It is easily do-able in the car. Make sure you lube them before inserting the tubes. Matt |
Rich Bontempi |
Jan 19 2004, 08:20 PM
914 Road Racer Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California |
For a 73 1.7 you should use the green ones which are the better quality. We use the green on the head and the case side!
Lo-Fi Version | Time is now: 27th September 2024 - 10:11 AM |
