Seat adjuster pulls - Look mom no pop rivets, Powder coated in black 2 for $39.99 or one for $25 |
Mikey914 |
Oct 1 2008, 10:39 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As always best prices for world members here -
This is a seat pull handle that has been machined out of steel. It is guaranteed not to break and installs simply. OEM were made from pot metal and over time broke as they fatigued. Some replacements have been made from plastic that flexes not giving a sold feel when using. They also require the use of pop rivets to install. This part solves some of the problems of it's predecessors. It will not break. It's 1/4" steel, your track rail will break before it does. Far superior to plastic. It installs using machine screws and lock washers. You can drill out the pop rivets and take the old broken stub out. after doing this you will need to drill the holes to accommodate the machine screws. The simply attach the new handle using the machine screws and lock washers. If your really worried about it coming loose you can use some lock-tite. I have added pictures from my installation. The process is simple. Drill out the old brass pop rivets, then drill out the track to accept the new Allen screws I used 9/32", but you may have to use 5/16" if you aren't right on the holes. Include are the handle and mounting hardware. Attached image(s) |
JazonJJordan |
Jul 22 2009, 08:19 AM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
Those look great Mike~
My -buy- list is getting longer..(sigh)... we will be in touch...Thanks! |
Mikey914 |
Jul 25 2009, 03:20 AM
Let me know when your ready I can put together a package for your that can save you a few bucks.
Thanks again - Mark |
johnpierre |
Jan 18 2013, 01:28 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
As always best prices for world members here - This is a seat pull handle that has been machined out of steel. It is guaranteed not to break and installs simply. OEM were made from pot metal and over time broke as they fatigued. Some replacements have been made from plastic that flexes not giving a sold feel when using. They also require the use of pop rivets to install. This part solves some of the problems of it's predecessors. It will not break. It's 1/4" steel, your track rail will break before it does. Far superior to plastic. It installs using machine screws and lock washers. You can drill out the pop rivets and take the old broken stub out. after doing this you will need to drill the holes to accommodate the machine screws. The simply attach the new handle using the machine screws and lock washers. If your really worried about it coming loose you can use some lock-tite. I have added pictures from my installation. The process is simple. Drill out the old brass pop rivets, then drill out the track to accept the new Allen screws I used 9/32", but you may have to use 5/16" if you aren't right on the holes. Include are the handle and mounting hardware. Are these still avaliable |
monkeyboy |
Jan 18 2013, 12:46 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Yes, I just bought some last week.
johnpierre |
Jan 22 2013, 02:58 AM
Lo-Fi Version | Time is now: 27th September 2024 - 06:57 AM |
