Conversion Begins, NA EJ25 Progress thread |
Carlitos Way |
Nov 25 2008, 10:38 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Well, the time has come to start documenting the whole ordeal and process. I've decided to do a subaru conversion. I hope I can have this done by January 1st, in hopes of doing the "Hangover Rally" once again.
The plans, somewhat flexible, involve: Renegade Hybrids Kit Renegade Hybrids Radiator EJ25 Normally Aspirated (USDM) engine Stock (Subaru) Fuel injection Stainless Steel fuel lines And some possible additions include: Adjustable Front Sway Bar to replace the current one Larger wheels Lower profile tires New interior Back pad Relocate power (Stereo) Still unresolved and undecided Fuel Pump. Which one, and where to mount. How to run coolant hoses How to vent warm air Whether or not to cut/replace current front bumper. So... this is her farewell picture Attached image(s) |
Carlitos Way |
Nov 25 2008, 10:42 PM
I was very lucky to have someone buy my motor including intake and exhaust, in one deal. So, this past Saturday, a little ahead of schedule, we ended up dropping the engine. The new owner drove down and took it home. Here's some pics of the progress.
First with the car jacked up. I used ramps in the front to give me a little more clearance. I also needed to have a little room to remove the fuel pump from under the fuel tank. Attached image(s) |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
This is in the classifieds..why?
CCLIN?? |
Carlitos Way |
Nov 25 2008, 10:44 PM
The bottom of the engine didn't seem too bad. You can see the Bursch and SS exhaust. And, she does like to mark her territory.
Attached image(s) |
Carlitos Way |
Nov 25 2008, 10:45 PM
Darn it. I meant to place this in the garage. Hopefully one of the admins can help me move it to the right place.
Gint |
Nov 25 2008, 10:55 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Coming right up...
bfrymire |
Nov 26 2008, 02:28 AM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Well, the time has come to start documenting the whole ordeal and process. I've decided to do a subaru conversion. I hope I can have this done by January 1st, in hopes of doing the "Hangover Rally" once again. The plans, somewhat flexible, involve: Renegade Hybrids Kit Renegade Hybrids Radiator EJ25 Normally Aspirated (USDM) engine Stock (Subaru) Fuel injection Stainless Steel fuel lines And some possible additions include: Adjustable Front Sway Bar to replace the current one Larger wheels Lower profile tires New interior Back pad Relocate power (Stereo) Still unresolved and undecided Fuel Pump. Which one, and where to mount. How to run coolant hoses How to vent warm air Whether or not to cut/replace current front bumper. So... this is her farewell picture Hope I am not bursting your bubble here... Have you ordered the renegade parts? the lead time is about 2 months, if I remember right.... You will not make the Jan 1st otherwise. To make it easier to do the conversion, you might want to use an aftermarket ECU. Either the stinger or the Link. Also, heater? You might as well take advantage of having hot water.... And where do you plan to get a motor? (JDMs are cheap from www.attarco.com ) Hope any of this helps somewhat. Best of luck with conversion, you will still finish before me! (I even have all the renegade parts already!!!) -- brett |
EdwardBlume |
Nov 26 2008, 08:00 AM
You braced the car up pretty well. How's your wallet braced? (IMG:style_emoticons/default/laugh.gif)
Carlitos Way |
Nov 26 2008, 10:08 AM
I have already ordered the kit from Renegade. I'm not going to get it as soon as I want... but there's a "chance" I might get a Christmas present from them this year.
ECU... for now it's the stock ECU. I just can't afford the $1300-1500 for a stinger or Link ECU right now. Especially when I already have the stock ECU. All I have right now is time... so I can work on the wiring harness until I get the conversion parts. |
Root_Werks |
Nov 26 2008, 10:26 AM
Village Idiot Group: Members Posts: 8,424 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Throw these jackstands out and get ones with pins. These have failed often enough that it's even affected one of our 914world members. Wiggling and jiggling the car around while doing work is what causes them to "let go".
Attached image(s) |
Carlitos Way |
Nov 26 2008, 10:38 AM
Throw these jackstands out and get ones with pins. These have failed often enough that it's even affected one of our 914world members. Wiggling and jiggling the car around while doing work is what causes them to "let go". Thanks for the tip. I will see what I can find... since these are going to be on for quite some time it seems. C:> |
Nana's_914 |
Nov 26 2008, 12:22 PM
Member Group: Members Posts: 98 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California |
I have already ordered the kit from Renegade. I'm not going to get it as soon as I want... but there's a "chance" I might get a Christmas present from them this year. ECU... for now it's the stock ECU. I just can't afford the $1300-1500 for a stinger or Link ECU right now. Especially when I already have the stock ECU. All I have right now is time... so I can work on the wiring harness until I get the conversion parts. UTEC from TurboXS is a good inexpensive option for controlling the stock ECU. I got a good used one for my WRX for $500. Works pretty well. |
Carlitos Way |
Nov 26 2008, 12:23 PM
Remember this is a Non-turbo (normally aspirated) engine conversion.
ONTHEGRIND |
Nov 26 2008, 12:32 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
That is gonna be a sweet setup. As I do alot with Subaru performance products which is 90 percent turbo stuff or cylinder heads for turbo engine's, But the Idea of a N/A engine in a Nine4teen is awsome.. Might be h20 cooled engine but it's got 4 Valves per cylinder..
westgl |
Nov 26 2008, 08:36 PM
Newbie Group: Members Posts: 41 Joined: 14-November 08 From: Rogue River, OR Member No.: 9,756 Region Association: None |
[quote name='Carlitos Way' date='Nov 25 2008, 08:38 PM' post='1105586']
Well, the time has come to start documenting the whole ordeal and process. I've decided to do a subaru conversion. I hope I can have this done by January 1st, in hopes of doing the "Hangover Rally" once again. Hey Carlitos way, Sorry, I bought the last engine/trans mount from Renegade, I did not buy the whole kit. I bought the motor adaptor, 9" clutch/pressure plate kit from KEP, and bought, Just the Engine/Trans mount from Renegade. I am using the stock WRX/STI radiator I have my NA EJ25 2.5L in my shop, My motor is out of a 2004' Subie Forester that had been rearended totaled, My Subie dude started the engine to let me hear it run, before I bought it he is the guy the Subaru dealer buys from when they need an engine for a customer. The speedometer in the car read 50,106 miles I got the complete wire harness Main ECU and all other computers, including Cruise control and engine fuse/relay box, both under dash and in passenger compartment I also got the water heater core, saw a great way to make the heater install on another web site as I buy and receive parts, I am chcking off the list and performing work as needed to keep my project going forward. It Sounds like we are both doing the same project |
westgl |
Nov 26 2008, 09:02 PM
Carlitos way
Have you thought about an exhaust, I heard a Subie motor with the stock subie exhaust manifolds cut a few inches after the merge, (then get rid of the crossover tube, you want an equal length exhaust) then a 911 Carerra muffler, it's a 2 tube in and 2 out muffler, it sounded awesome with out being loud and nosiey. It sounded like a carerra 6 cyl. With the exhaust, You should be looking at 185-195HP NA stocker Poormans Lotus Elise? 11.0 Lbs. per H.P. Hmmmm Hope your Brakes are up to it? Well! If you were any good you wouldn't need brakes, JUST the go button. (IMG:style_emoticons/default/blink.gif) lol West |
Carlitos Way |
Nov 26 2008, 11:41 PM
FOr an exhaust, I'm thinking about doing it the "easy" way as much as possible. I hope I can find just a stock manifold from a wrecking yard, chop it off a little after the two sides merge, weld the flange into a muffler, running it out the same location as stock. Might be a little too much to fit on that side, but only time will tell. Found a local guy who likes to fabricate, and he sounded excited about helping me with the exhaust. Now it's just a matter of going to the junkyard and finding one.
Carlitos Way |
Nov 26 2008, 11:45 PM
So, this is what she looks like with the engine off. I've taken a couple of days to settle down and now I'm working toward preparing the engine bay. The plans call for a stock ECU. WOuld love to mount it in the "stock" 914 location, but I'm not sure my wiring harness will reach. I have to do a mock up to see how far it will go. Another choice is to mount it in the rear trunk, but I'm avoiding holes, until I'm SURE I know what I'm doing.
Attached image(s) |
bfrymire |
Nov 26 2008, 11:50 PM
I have already ordered the kit from Renegade. I'm not going to get it as soon as I want... but there's a "chance" I might get a Christmas present from them this year. ECU... for now it's the stock ECU. I just can't afford the $1300-1500 for a stinger or Link ECU right now. Especially when I already have the stock ECU. All I have right now is time... so I can work on the wiring harness until I get the conversion parts. I picked up my link used for $500. If you look, you can find a good deal. I personally think the ECU is worth it, just for the time it saves makes it worth it to me. And I am going to get the exhaust stubs from outfront motorsports, and fabricate from that. -- brett |
Carlitos Way |
Nov 26 2008, 11:51 PM
And this is what I have left from the power train. Just the tranny. But.. do they all look this gross inside? Or was my rear main seal leaking?
On another note, I'm thnking about doing some minor reconditioning on this tranny. It has a slight grind between first and second. Dr. Evil might be doing the honors, once I decide to pull the trigger. Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 07:46 AM |
