#11 Fuse on '71 1.7?, It's listed as Int. light, warning light, buzzer ... it fails when |
Eddie914 |
Apr 22 2009, 02:58 PM
Unregistered |
My '71 3.2 (converted from a 1.7) has lost it's fog lights (It's ONLY headlights since the original pop up headlights have been removed).
I am working on tracing the short but noticed that the #11 fuse (second from the right - near the center of the car) fails when the foglights are switched on. All the documentation I review indicates that #11 should be for Interior lights, warning light and buzzer (none of which remain in my car) and #10 should be fog lamps. Can anyone shine a little light on this subject for me. The foglights have been working great for the last few years until a lapping day last month where it rained ALL day. Thanks Eddie |
SLITS |
Apr 22 2009, 03:46 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Pull the fog lamp off, remove the lens assembly and check the screw terminal on the back of the reflector housing for corrosion or shorting. The power feed wire and crossover to the second fog lamp come in there too.
Fog lamps also run thru a relay on the fuse panel ... As far as the fuse #, how many hands have been into the fuse panel. It's only spade connectors and they could have been switched at some point (10, 11 & 12 appear to be joined anyway on the hot side |
swl |
Apr 22 2009, 07:23 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
I pulled out the magnifying glass and had a look at the 71 usa wiring diagram. Wanted to see if the fog lamp relay(53) was somehow associated with fuse 11. Couldn't really see anything though I confess that I can't really figure out that combo relay(27). Nothing jumps out at me so Slits may have the right idea that something has been screwed up along the way.
Maybe another way of troubleshooting might be remove the fog light relay and poke it with a voltmeter. Pin 30 should show 12V. This is the power that gets switched to the fog lights. It comes directly from fuse 10 if the fuse box is still wired correctly. It should be there even with the key off. If you get 12 V on pin 30 then look at pin 85. That is the pin that will fire the solenoid of the relay. It looks like your lights need to be on for that to happen. I think that is where the combo relay comes in - provides power to the solenoid if the headlights are on. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:59 PM |
