Air foils under car infront of engine., engine cooling |
Geezer914 |
Aug 22 2009, 09:42 AM
Geezer914 Group: Members Posts: 1,656 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
How do the plastic air foils that mount under the car, infront of the engine, help cooling? Are they worth adding?
Bartlett 914 |
Aug 22 2009, 09:48 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
They are helpful. Use them! They mix the air up so air can be picked up better otherwise the air is is ducted through under the car. |
type47 |
Aug 22 2009, 09:49 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
My guess is that they are worth having installed since the factory installed them for some reason. They mount on the bottom of the back edge of the firewall by 3 or 4 6mm screws, if I recall correctly. Do a search here as there were some recent post including a pic of the flaps installed.
dr914@autoatlanta.com |
Aug 22 2009, 09:50 AM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes yes yes.
SLITS |
Aug 22 2009, 09:52 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
They were mounted with 3 7mm? bolts on each side. If the car came equipped with them, there should be weld nuts on the rear body pan lip. You can easily drill and use regualar fastners ... no biggie.
As I remember, the are spaced about 15" apart from the centerline of the engine or car (There is a diagram in some manual that I have or try Pelican Parts tech section). Purpose is to create lo pressure area under the cylinders to help suck air and aid in cooling (they do work well). |
Johny Blackstain |
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
They cause a vacume to occur under the engine @ speed so as to help draw cold air in from the top & through the engine.
ConeDodger |
Aug 22 2009, 10:05 AM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Engineers sit in meetings with accountants and argue for inclusion. The accountants in most cases have a lot of pull because the bottom line depends on them. You can bet your bippy (random Laugh-In reference) that these wouldn't be there if they didn't help. (IMG:style_emoticons/default/biggrin.gif)
jimkelly |
Aug 22 2009, 10:20 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pic
Attached image(s) |
Katmanken |
Aug 22 2009, 10:24 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
They induce turbulence which helps throw air along the underside of the engine as well.
Bruce Hinds |
Aug 22 2009, 10:25 AM
V-8 madness Group: Members Posts: 734 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Like Johny says above....
Actually they create a low pressure area behind them at speed and which helps draw down the air across they cylinders. Some of the race cars with big air dams actually remove the rear bumpers to help draw the cooling air out. |
JazonJJordan |
Aug 22 2009, 06:10 PM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
ClayPerrine |
Aug 22 2009, 06:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Like Johny says above.... Actually they create a low pressure area behind them at speed and which helps draw down the air across they cylinders. Some of the race cars with big air dams actually remove the rear bumpers to help draw the cooling air out. (IMG:style_emoticons/default/agree.gif) That is the reason the 914-GT didn't have a rear valence. |
martinef1963 |
Aug 23 2009, 02:49 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Are these "YEAR SPECIFIC" installs, or just certain years had these introduced?
thanks, Fern |
martinef1963 |
Aug 23 2009, 03:01 AM
Okay, I'll have to goof on myself here, had a stupid moment (IMG:style_emoticons/default/sad.gif) and asked the same question twice.
Just wanted to know if it was year specific cause I don't recall predrilled holes on my 72, but then again I wasn't looking for them. Thanks, Are these "YEAR SPECIFIC" installs, or just certain years had these introduced? thanks, Fern |
ClayPerrine |
Aug 23 2009, 03:45 AM
They were introduced on the 73 model year, and were on all 914s after that.
thesey914 |
Aug 23 2009, 04:01 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
ever fitted on a six?
ClayPerrine |
Aug 23 2009, 04:32 AM
thesey914 |
Aug 23 2009, 04:38 AM
Interesting....I have the flaps but no mounting holes. I'll have to look at fitting them again.
ellisor3 |
Aug 23 2009, 09:58 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
Part Number??? Did not see it on PET (IMG:style_emoticons/default/confused24.gif)
IronHillRestorations |
Aug 24 2009, 07:50 AM
I. I. R. C. Group: Members Posts: 6,759 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Not sure but I think they are NLA
Lo-Fi Version | Time is now: 26th September 2024 - 09:47 PM |
