Caliper Cleaning? |
Caliper Cleaning? |
Aaron Cox |
Mar 15 2004, 06:42 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Hey guys,
i have some M calipers that im cleaning. i want to get them clean enough to the point where i can pain them red with caliper paint (yeah i know...ricer style (IMG:style_emoticons/default/laugh.gif) ). they are still loaded (ie pistons and seals in bore, and bleader valve in place). i tried rubbing alcohol....not very effective. brake cleaner says it eats rubber so, that's out of the question. |
davep |
Mar 15 2004, 09:35 PM
914 Historian Group: Benefactors Posts: 5,195 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I sandblast them, then use metal prep (phosphoric acid). Be careful of brake fluid in the sandblaster though, it ate through the rubber gloves. Rinse with alcohol after that, and before painting.
Andyrew |
Mar 15 2004, 09:42 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
A wire brush, like you would use on your grill (cooking), but a little softer. a nice long one, and you can take it to bare metal, super clean like nothing. Just dont be afraid to scrub it hard. I did it on mine and they looked shiny before I painted them.
Works alot better than chemicals. Andrew |
Aaron Cox |
Mar 15 2004, 09:43 PM
QUOTE(Andyrew @ Mar 15 2004, 08:42 PM) A wire brush, like you would use on your grill (cooking), but a little softer. a nice long one, and you can take it to bare metal, super clean like nothing. Just dont be afraid to scrub it hard. I did it on mine and they looked shiny before I painted them. Works alot better than chemicals. Andrew thanks. ill try that |
ChrisReale |
Mar 15 2004, 10:22 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
QUOTE(acox914 @ Mar 15 2004, 04:42 PM) . brake cleaner says it eats rubber so, that's out of the question. You plan on using these without rebuilding them? Do you know the history of these calipers? I think you'd be better off rebuilding them |
Rusty |
Mar 16 2004, 12:09 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
If you're going to take them to the sandblaster...
1. Leave your pistons and rubber seals in place. 2. Get some cheap 6" steel brake lines. Cut them in half. Fold the cut end over and crimp shut tightly. Screw into the brake line fitting. That should keep crap out of your calipers. I agree with previous advice, though. If you don't know the history on the calipers, rebuilding them is a good idea. Simply because they came off a running car doesn't mean squat. Who knows the last time they changed their fluid? -Rusty (IMG:style_emoticons/default/smoke.gif) |
tat2dphreak |
Mar 16 2004, 02:31 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
rebuild tem... it's cheap and easy!
to clean them... DON't Put them in a parts washer of b-12... ask me how I know... |
Aaron Cox |
Mar 16 2004, 06:22 PM
they are very good calipers. have like 50k on them. seals look BRAND NEW! pictons are not pitted or anything. they are loaded calipers tho..... so i want to clean them and not blast them.....
Eric_Shea |
Mar 16 2004, 08:19 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Glass bead blast them. Take them to a plater. They'll plate with the seals in them. Look like brand new...
Attached image(s) |
Aaron Cox |
Mar 16 2004, 08:24 PM
how much does "glass beading" cost? can you paint over the plating?
Eric_Shea |
Mar 16 2004, 08:33 PM
Most platers will have a bead blasting cabinet. It would be hourly at that point. Probably $20-30 to clean, another $20-30 to plate... why would you paint them once you plate them?
Oh... never miiiiiiiiiiiiiind QUOTE ricer style (IMG:style_emoticons/default/wacko.gif) |
Aaron Cox |
Mar 16 2004, 08:35 PM
because plating is for Concourse weenies! i want red calipers! (IMG:style_emoticons/default/laugh.gif) (pseudo "Big reds" ) no plating then!
Aaron Cox |
Mar 22 2004, 09:51 PM
Hey, just a public thanks to MXMARK for putting my calipers in his solvent tank and cleaning them. Thanks, (IMG:style_emoticons/default/beerchug.gif)
Aaron Oh and they are being rebuilt (IMG:style_emoticons/default/wink.gif) |
Greg |
Mar 23 2004, 09:38 AM
Copper Metalic Member Group: Members Posts: 50 Joined: 14-March 03 From: Bellevue, WA Member No.: 428 |
last year I used break cleaner and wire wheeled/ wire brushed mine before I painted them with high temp engine paint. I then baked them in my oven at 200 degrees (oh ya, my wife was not pleased.) The paint has held up just fine since then. be careful about getting brake fluid on the paint though, works just like a solvent. I think the "Mini" Reds look great.
Lo-Fi Version | Time is now: 27th September 2024 - 10:06 AM |
