Wiring diagram for the dash gages, Anyone have one? |
JRust |
Feb 20 2010, 05:20 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I've had my gages out for a while. Just putting my interior back in the LE. Went to do the gages & while there are only so many options. There are a few different combinations. Meaning I would probably get them wrong. Figured to see if anyone had a diagram for them
rick 918-S |
Feb 20 2010, 05:25 PM
Hey nice rack! -Celette Group: Members Posts: 20,680 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I've had my gages out for a while. Just putting my interior back in the LE. Went to do the gages & while there are only so many options. There are a few different combinations. Meaning I would probably get them wrong. Figured to see if anyone had a diagram for them I think there are diagrams on the bird board. I think... (IMG:style_emoticons/default/idea.gif) |
Todd Enlund |
Feb 20 2010, 05:26 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I've had my gages out for a while. Just putting my interior back in the LE. Went to do the gages & while there are only so many options. There are a few different combinations. Meaning I would probably get them wrong. Figured to see if anyone had a diagram for them Take your pick: http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
JRust |
Feb 20 2010, 05:44 PM
I was hoping for a nice picture of the backside hooked up (IMG:style_emoticons/default/confused24.gif) . Using that wiring diagram will take brain power (IMG:style_emoticons/default/dry.gif) . Everyone should know by now I am in short supply (IMG:style_emoticons/default/headbang.gif)
JeffBowlsby |
Feb 20 2010, 08:13 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Ya mean like this here? From my 914 Classic site:
Attached thumbnail(s) |
JRust |
Feb 20 2010, 08:22 PM
watsonrx13 |
Feb 21 2010, 06:58 AM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Jamie, this is the diagram I made for my '74, hope it helps.
-- Rob |
StratPlayer |
Feb 21 2010, 11:23 AM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
combo gauge setup
Attached image(s) |
JRust |
Feb 21 2010, 11:42 AM
I got it off of Jeff's diagram. Thanks for all the help guys. Still a ways from being able to actualy test it (IMG:style_emoticons/default/dry.gif) . It is hooked up right though thanks to your help (IMG:style_emoticons/default/aktion035.gif)
flipb |
Mar 9 2010, 01:00 PM
Senior Member Group: Members Posts: 1,754 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
My gauges have some wiring quirks that I'm hoping to address soon. This thread will be a great help.
Two quick questions: 1. I know of at least one wire back there that shorted out and melted its sheath... What gauge wire do I need to replace it? 2. Is it necessary to remove the dash bottom to access the various electrical hookups on the headlight switch? The extent of my electrical experience has been replacing fixtures and outlets in my house. Appreciate any additional tips for the clueless. |
McMark |
Mar 9 2010, 01:38 PM
1. Most wires are 18g, but some are larger.
2. The headlight switch has a lot of connections. If you drop the relay panel (two screws), unscrew the knob and then unscrew the escutcheon (the small aluminum ring) which holds the switch onto the dash, you can then pull the switch down enough to see what is what. |
nivekdodge |
Jun 16 2022, 08:03 PM
Member Group: Members Posts: 262 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
GeorgeKopf |
Jun 16 2022, 08:15 PM
Member Group: Members Posts: 186 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
This is mine from a 73.
JeffBowlsby |
Jun 16 2022, 09:04 PM
GeorgeKopf |
Jun 29 2022, 07:09 PM
I was hoping for a nice picture of the backside hooked up (IMG:style_emoticons/default/confused24.gif) . Using that wiring diagram will take brain power (IMG:style_emoticons/default/dry.gif) . Everyone should know by now I am in short supply (IMG:style_emoticons/default/headbang.gif) @JRust I found some pictures of the gauges that show the connections pretty clearly. The lights are not plugged in (blue/black wire), so the empty sockets are the dash lights. Combo Gauge Speedometer (The black cable on the right is the tripometer reset cable). Tachometer Good Luck. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:33 AM |
