CV Spiral Pins AKA VC Roll Pins, Are Used Ones OK? |
bandjoey |
Jun 30 2010, 05:05 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Started the CV cleanup and lube prior to reassembly to the tranny. PO only had 1 Roll Pin per CV in place, no Special Washers or Gaskets. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) The leaking seal was a blessing - - I didn't lose the axle going down the road!
I have another used axle with the roll pins still in place. Can (and how) I remove these and use them on my car? Is this only a replacement with a new part, part? Pelican has them cheap, but it's another week of being down to get them. Thanks As Always you guys. |
jt914-6 |
Jun 30 2010, 05:22 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Bill...I would say that they can be reused as long as they were tight. As far as removing one.....big a$$ vice grips. You might check around locally for a shop that might have some new/used.....my $.02
Shade Tree |
Jun 30 2010, 05:23 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I was missing one and just grabbed one out of my parts car. No problems with it after several thousand miles. They come out easy. I just carefully grabbed it with pliers..
jmill |
Jun 30 2010, 05:56 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
If they were tight I'd have no issue reusing them.
bandjoey |
Jun 30 2010, 08:55 PM
I gave a prelim twist with some pliars earlier and they were tight. I'll shoot a litttle pb blaster and get them out tomorrow. Thanks
HAM Inc |
Jul 1 2010, 09:31 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
I push them out with a pin punch. They tap right out and don't suffer damage from vise-grips that way.
TheCabinetmaker |
Jul 1 2010, 11:43 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I push them out with a pin punch. They tap right out and don't suffer damage from vise-grips that way. (IMG:style_emoticons/default/agree.gif) Drit pin punch and a hammer. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:51 AM |
