2.0L prototype air intake parts in factory manual |
JeffBowlsby |
Dec 11 2010, 09:19 AM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Stumbled on this recently...how many differences can you see in this drawing, from what was actually produced? I count about 8. This is not the only prototype stuff in the factory manual. Thought some of you would find it interesting.
Attached thumbnail(s) |
sean_v8_914 |
Dec 11 2010, 10:43 AM
1 filter housing size
2 shape 3 bolt down air cleaner no clips 4 wheres the air temp go? 5 no center stiffening tubes 6 box body is on the right instead of left or the whole thing is 180 clocked as it mounts to block 7 air bypass hole/adjuster 8 throttle body clocked 90 deg off, wheres the cable holder? 9 split down the vertical plane like a 1.7 OK Jeff, what differences did you not? htis was fun. |
904svo |
Dec 11 2010, 11:26 AM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
No air filter shown or part number not number 8.
Tom_T |
Dec 11 2010, 12:29 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Hey Jeff, I also thought it was interesting that they always showed the "wrong" 2.0 airbox on the sales brochure cutaways for 73-76 as well (it always showed the correct "Banana" muffler, so it's a 2.0 - see below).
I guess it was more of a hassle/cost to change the artwork back in the pre-CAD days! (IMG:style_emoticons/default/biggrin.gif) 73-74 2L - . 75-76 2L - . BTW all y'all - these pix above are courtesy of Jeff's excellent 914 website too! . However, I've never seen a 2L airbox with that pattern on top either!? (IMG:style_emoticons/default/confused24.gif) The early ones like mine below come the closest, but no cigar! . (IMG:style_emoticons/default/shades.gif) |
Tom_T |
Dec 11 2010, 12:42 PM
To my eyes in this larger scale pic below (also one of Jeff's) - it looks more like they're representing a squarish box with a neck attached to it (2 pieces), rather than 1 piece with the neck a single form extension from the square-ish air filter housing area on mine in the post above.
. There were also at least 4 embossed/stamped patterns on the 2.0L air filter boxes, as follows: Early 73 MY - Diamonds + cross-ribs, like mine in the pic in the prior post (GA motors) ....................... also early 73 - a similar version with diamonds but no cross-ribs Late 73 - 74 MYs - Cross-ribs only (GA motors) 75 -76 MYs - Smooth tops (GC motors) I'm not sure if it followed the same pattern for the GB Euro/World 2.0L motors, but suspect it did. |
DanT |
Dec 11 2010, 01:26 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
early '74 2.0L aircleaner.....slight color change (IMG:style_emoticons/default/biggrin.gif)
DanT |
Dec 11 2010, 01:27 PM
and my early '75 2.0L aircleaner is identical to this except without the color change (IMG:style_emoticons/default/smile.gif)
Tom_T |
Dec 11 2010, 01:30 PM
Hey Dan, do your tins match? (IMG:style_emoticons/default/blink.gif)
Late 73 ... also 74 My, no color change! (IMG:style_emoticons/default/biggrin.gif) |
Tom_T |
Ooops, sorry for the dupe, I guess I double-clicked!
DanT |
Dec 11 2010, 01:40 PM
yes they do (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/drooley.gif)
Tom_T |
Dec 11 2010, 01:47 PM
Well - if the smell of petrol in the morning doesn't wake you up, that ORANGE!!!! certainly will! (IMG:style_emoticons/default/biggrin.gif) |
DanT |
Dec 11 2010, 01:49 PM
all orange....
the entire car. Smoothed and painted top, painted sail panels, engine compartment, trunks it was ORANGE (phoenix red to be exact (IMG:style_emoticons/default/smile.gif)) |
bandjoey |
Dec 11 2010, 11:36 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
all orange.... the entire car. Smoothed and painted top, painted sail panels, engine compartment, trunks it was ORANGE (phoenix red to be exact (IMG:style_emoticons/default/smile.gif)) Small HJ (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) (Dan's Car??) |
DanT |
Dec 12 2010, 10:45 AM
just one.... (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
davep |
Dec 12 2010, 12:41 PM
914 Historian Group: Benefactors Posts: 5,195 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I noticed at Mike G's place, a couple of weeks ago, that he had at least three different housings.
Tom_T |
Dec 13 2010, 03:22 AM
I noticed at Mike G's place, a couple of weeks ago, that he had at least three different housings. That must have been one crowded engine compartment Dave! (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:38 AM |
