OT: IMS Bearing Replacement on Luck's 986., This is going to be a major part of my business... |
Series9 |
Apr 4 2011, 08:27 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
The victim:
Attached image(s) |
Series9 |
Apr 4 2011, 08:29 PM
Assume the position, the service position:
Attached image(s) |
Series9 |
Apr 4 2011, 08:32 PM
914ish:
Attached image(s) |
Series9 |
Apr 4 2011, 08:33 PM
Muffler out. That was one of the more challenging parts of the disassembly.
Attached image(s) |
Series9 |
Apr 4 2011, 08:35 PM
Tranny out:
Attached image(s) |
Series9 |
Apr 4 2011, 08:36 PM
Bearing coming out:
Attached image(s) |
Series9 |
Apr 4 2011, 08:40 PM
New bearing in.
I'm waiting on the clutch kit and flywheel bolts in UPS tomorrow. More to follow. All 986s built between 1997 and 2005 need this retrofit. I'm going after this market. $2000 each, including the bearing for a manual transmission Boxster. Attached image(s) |
Jake Raby |
Apr 4 2011, 08:41 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Guess who designed that tool you are using :-)
And perfected the extraction process too! have fun. |
T H O M A S |
Apr 4 2011, 08:58 PM
Senior Member Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None |
i am going to do the same thing next weekend,are you changing the RMS too?
jim_hoyland |
Apr 4 2011, 08:59 PM
Get that VIN ? Group: Members Posts: 9,418 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Nice pics Joe; what is the problem with the IMS bearing and what does one see whan it goes bad ?
I picked up a low milage '98 986 last year, currentlu 45K miles. Curious as to what to expect. Attached image(s) |
Series9 |
Apr 4 2011, 09:06 PM
Series9 |
Apr 4 2011, 09:07 PM
biosurfer1 |
Apr 4 2011, 09:27 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
How long did the change out take and how much time do you think you'll knock off once you've done it a couple times?
Series9 |
Apr 4 2011, 09:39 PM
How long did the change out take and how much time do you think you'll knock off once you've done it a couple times? It's a two-day project. A one-day delivery is certainly possible, but I'll need some more experience. I've already decided that a manual-transmission 986 will be $2000, LNE bearing included. The Tiptronic will probably be more, but I won't know how much more until I do one. The first one will be $2000, too. I'll need the experience first. Clutch and RMS are extra. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:54 AM |
