Rear shock additional springs NLA - what r u using?, (the rubber shock stops for Boge) |
tod914 |
Sep 30 2011, 07:41 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Replacing the oem rear shocks on my car with Boges. Seems the 914 333 053 01 additional springs are no longer available. Is there a Koni part or other substitute?
Thanks, Tod |
jcd914 |
Sep 30 2011, 08:26 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have used both Koni and Boge Front bump rubbers placing them upside down on top of the rear shock. Koni makes a nice foam bump stop but like all the front bump stops they are made for the larger diameter front shock shaft and won't attach to the upper shock washer for the rear shock.
Not ideal but functional. Jim Even back when the rear bump stops (additional springs) were available they were about $70 each. |
tod914 |
Sep 30 2011, 01:32 PM
Thanks for the info Jim. Have a leed on a set of used ones.
Lo-Fi Version | Time is now: 27th September 2024 - 10:37 AM |
