> 914World Classifieds Rules
> Performance Front and Rear Suspension Parts
Britain Smith
post Oct 26 2011, 09:02 PM
Nano Member
Several High Performance parts off my 914. All of these parts have very low mileage as the car is a dedicated AX car. All the parts located in Fullerton, CA area, local Pick-up preferred. If you would like items shipped, please inquired regarding shipping costs.
Front:
Bilstein Struts with Raised Spindles, 3.5" Caliper Spacing, 911 Hubs, 45mm Studs w/ Lugs, and Rebuilt Bilstien shocks: SOLD
S-Calipers with Stainless Pistons and Fresh Braided Brake Lines: $700
SC Cross-drilled Rotors: $100 pair (new $127 each)
(IMG:http://www.914world.com/bbs2/uploads_offsite/a6.sphotos.ak.fbcdn.net-364-1319684530.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/a2.sphotos.ak.fbcdn.net-364-1319684531.3.jpg)
Elephant Racing Bump-Steer Kit: SOLD
Wevo Camberking Strut Mounts (used less than 1 month): SOLD
Control Arms with Needle Bearings, 21mm Torsion Bars, Sway-Bar Tabs and Fresh Ball Joints. Steering Rack with Turbo Tie-Rod Ends and Rothsport Racing Bump Steer Kit and Steel Cross-brace. Billet Steering Biscuit to correct steering u-joint angle with rack spacer (Control Arms have been seam welded and machined to fit inside 15" Fuchs): SOLD
Tarrett Engineering 22mm Hollow Sway-Bar with Fresh Bushings: SOLD
Rear:
Seam-Welded and Trimmed Trailing Arms with Needle Bearings, Fresh Wheel Bearings, and 944 Turbo CV Conversion including 100mm 6-Bolt CV Joints, machined 914 Axles, 911 ('69-73) Hubs and 60mm Studs w/ Lugs. (brackets for e-brakes have been removed): $650 (Needle Bearing are $400 new)
(IMG:http://www.914world.com/bbs2/uploads_offsite/a5.sphotos.ak.fbcdn.net-364-1319684537.10.jpg)
SC Rear M-Calipers and SC Rotors: $100
All prices are listed without Shipping costs. I accept payment via paypal. Offers on package deals accepted.
-Britain
Replies(1 - 8)
bdstone914
post Oct 27 2011, 07:58 AM
bdstone914
Why are you selling off all that nice suspension stuff?
Are you parting out the car or getting better parts?
Bruce
Britain Smith
post Oct 27 2011, 09:59 AM
Nano Member
Have you seen this.
http://www.914world.com/bbs2/index.php?sho...3579&st=320
-Britain
Britain Smith
post Oct 27 2011, 10:15 AM
Nano Member
The following parts have been sold:
Bilstein Struts w/ inserts
Elephant Bump-Steer Kit
Tarrett Sway Bar
Front Control Arms w/ Torsion Bars
Steering Rack w/ Billet Biscuit
jpnovak
post Oct 27 2011, 10:20 AM
They call me "Nanoman"
What about the rear coil-over setup? What is the spring-rate?
Britain Smith
post Oct 27 2011, 10:31 AM
Nano Member
Somehow I accidentally got two threads going...oh well.
Rebuilt Bilstien Shocks with Coleman Threaded Collars, Aluminum Hats, 275lb and 325lb springs: $450
(IMG:http://www.914world.com/bbs2/uploads_offsite/a3.sphotos.ak.fbcdn.net-364-1319684988.1.jpg)
Britain Smith
post Oct 28 2011, 11:13 AM
Nano Member
CamberKing Sold.
Britain Smith
post Nov 10 2011, 02:48 PM
Nano Member
All that is left are the S-Calipers, Rear Trailing arms with 944 Turbo Axle Conversion, Rear Shocks with 275lb and 325lb Springs and Rear Brakes/Rotors.
_Britain
LotusJoe
post Nov 10 2011, 04:03 PM
Europa Twink Driver
QUOTE(Britain Smith @ Oct 27 2011, 08:31 AM) *
PM sent on rear shocks and coil overs
- Lo-Fi Version Time is now: 23rd November 2024 - 08:00 AM
