914 returns to life, new engine is in |
Demick |
Sep 3 2004, 09:11 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
New engine is in the car and fired it up on Wednesday night. Runs well, although I still have some tweaking to do to the F.I due to the cam and compression changes that I made. Hoping to sort through those issues and get enough miles on it over the next week to take it autocrossing on the 11th (81 miles so far).
Here's a summary of the last 2 months: First: Drop the engine. Attached image(s) |
Demick |
Sep 3 2004, 09:12 AM
Let's admire how beautiful a dirty old Type 4 looks. Bleach!
Attached image(s) |
Demick |
Sep 3 2004, 09:13 AM
Stripped down to a longblock (more yuck!)
Attached image(s) |
Demick |
Sep 3 2004, 09:15 AM
Peeking into the #3 intake port is the culprit - a dropped valve seat holding open the valve.
Attached thumbnail(s) |
Demick |
Keep tearing it down until the case is ready to be split....
Attached image(s) |
Demick |
Sep 3 2004, 09:16 AM
Split the case...
Attached image(s) |
Demick |
Sep 3 2004, 09:18 AM
Rebuilt heads back from the shop. All new valves, seats, guides, springs, etc etc. Lots 'o cracks had to be ground out and welded. These alone lightened my wallet by $1650. Ouch!
Attached image(s) |
Demick |
96mm pistons and cylinders from Jake Raby.
Attached image(s) |
Demick |
Sep 3 2004, 09:19 AM
Build that sucker back up to a longblock.
Attached image(s) |
type47 |
Sep 3 2004, 09:20 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
we see you are having fun! can you regularly add more pix of your progress. it would be a great informational tool.
Demick |
Sep 3 2004, 09:21 AM
Just about ready for the install.
Attached image(s) |
machina |
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Nice work.
Amazing how dirty they can look, makes the new parts look even better. dr |
Demick |
Sep 3 2004, 09:23 AM
That's all I got for pictures. While the engine was out I took advantage of the time to rid the firewall of that big ugly heavy pad. Also moved the fuel pump to the front trunk and ran steel fuel lines through the tunnel. And was finally able to change my rear flexible brake hoses!
Demick |
Lo-Fi Version | Time is now: 27th September 2024 - 01:40 PM |
