22mm Sway bar hitting gas tank?, Interference? |
bfrymire |
Jul 22 2012, 07:11 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I am installing a 22mm bar and it appears to be hitting the gas tank. Any ideas? is this common?
I pulled the old bar out and tried to install this one. Any help? -- brett |
Mike Bellis |
Jul 22 2012, 07:14 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Your mounts may be too high. Some use a small piece of carpet if the interference is not too much. If your gas tank will not sit correctly, you have a problem.
shoguneagle |
Jul 22 2012, 07:26 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
The gas tank will also hit the sway bar if it is allowed to become centered to low in the mounting saddles. Watch were the mounting saddles get placed along with padding along the edges on back side of the tank.
If you placed the mounts on the flange edges on each side as the instructions gives on the instruction sheet, It is probably the tank is allowed to set too low in the mounting saddles. How do I know?? Using after market sway bar (22mm) and did just the above, The attachments to the top of the gas tank should just barely clear the hood thus fitting into the knitches and ribs of the hood. Steve |
bfrymire |
Jul 22 2012, 08:17 PM
THanks Guys!
I will check the tank mounting and the location of the holes... -- brett |
Lo-Fi Version | Time is now: 27th September 2024 - 12:34 PM |
