Maximum rear wheel backspacing? |
Eddie914 |
Oct 26 2004, 12:42 PM
Unregistered |
At what backspacing do the rear tires/wheels contact the rear inner fenders?
Assume: -2 degrees camber. 245/45/16 tire 16 x 9 wheel Thanks Eddie |
Brett W |
Oct 26 2004, 12:47 PM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
My 15x8 with a 9.5 in slick would hit with a backspace of 5 inches. Ran about the same settings as far as suspension goes. Put a .250 spacer and problem solved.
Mueller |
Oct 26 2004, 02:25 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
a 16*8 rim with a 55mm offset and with 225 width tire hit both the trailing arm and the trunk wall....backspacing wise, if you included the thickness of the rim lip, you'd have a rim with about a 6.5" backspace which is too much.
Lo-Fi Version | Time is now: 27th September 2024 - 06:26 AM |
