Using turn signal turns on my highbeams. |
tornik550 |
Sep 28 2012, 08:32 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Ever since I have owned my car, if I have my headlights on and I use the right turn signal, it turns on or off my high beams. It's very annoying when I am at a stop light and I turn my right signal on and flash my high beams into oncoming traffic. I took the turn signal switch out to look at it and clean it. Everything appears normal. Any ideas?
Mike Bellis |
Sep 28 2012, 08:47 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The highbeams work by sending a momentary ground to the relay. Something is loose or touching something it shouldn't. Study the brown/white wire and it's connection right at the end of the stalk.
Nine_14 |
Sep 29 2012, 07:07 AM
Member Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
Have you checked all Ground connections ?
tornik550 |
Sep 29 2012, 12:56 PM
The highbeams work by sending a momentary ground to the relay. Something is loose or touching something it shouldn't. Study the brown/white wire and it's connection right at the end of the stalk. Every thing in the general area of the switch looks ok. Could this just simply be that I have a bad switch? |
Lo-Fi Version | Time is now: 27th September 2024 - 09:00 AM |
