Two steps forward, One step back |
Elliot Cannon |
Jan 22 2013, 08:17 PM
Starting to put my five lug conversion back together and discovered I have two different wheel hubs. I didn't realize just how different till I started installing them. The one on the left has subtle differences. It is almost 1/4 of an inch smaller at the outer flange diameter. The wheel lug holes are the correct bolt pattern but are closer to the outer edge of the hub flange. The not so subtle difference is, when installed, it sits in too far and rubs... badly. To make things worse, I bought them so long ago, I don't even remember who I bought them from. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/laugh.gif) Looks like maybe a trip up to Parts Heaven. I wonder now, if I can tap the hub out without damaging my new wheel bearing? I know. I know. I should have checked them more carefully. Sheesh! You guys are starting to sound like my wife. (IMG:style_emoticons/default/lol-2.gif)
Attached image(s) |
TargaToy |
Jan 22 2013, 08:21 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 694 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Are the back sides of the flanges different? ie: does one of them have beefed up reinforced areas behind the stud holes?
Mike Bellis |
Jan 22 2013, 08:28 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Too bad your timing isn't better. I drive near PH every day AND I'm heading to King City (Fort Hunter Liggett) tomorrow. BTW. I'm usually down at FHL once a week...
draganc |
Jan 22 2013, 08:29 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
That sucks! I think you will have to replace the bearing also.
Good luck, Dragan |
Mike Bellis |
Jan 22 2013, 08:30 PM
BTW, I'll be heading back to FHL 1-28-13 if I can help you with delivery.
Elliot Cannon |
Jan 22 2013, 08:40 PM
Elliot Cannon |
Jan 22 2013, 08:48 PM
Are the back sides of the flanges different? ie: does one of them have beefed up reinforced areas behind the stud holes? Actually both do. I'll have take the other one out tomorrow and take a really close look at them. (Something I should have done anyway). Then I guess I'll order two new wheel bearings. Faauuck!! It takes considerable effort to get the hubs out and I don't know if I want to trust the bearings after beating on them like that. (IMG:style_emoticons/default/lol-2.gif) |
McMark |
Jan 22 2013, 11:17 PM
Doesn't the bearing retainer keep everything in place? I use a slide hammer to pop the hub out in one quick motion.
Elliot Cannon |
Jan 22 2013, 11:26 PM
Doesn't the bearing retainer keep everything in place? I use a slide hammer to pop the hub out in one quick motion. I do basically the same thing except I drive it out with a punch from the other end not unlike the description in the Haynes manual. Either way you do it, it places a side impact on the bearings that they were not (I think) designed to take. If I'm wrong about that and the experts agree that the bearings can be re-used after banging on them like that, I'm all for it. I just installed new ones and would rather not have to buy two more but I'd hate to get it all back together and have one or both fail because they were damaged driving out the hubs. Has anyone had experience where they banged out the hubs, yet still re-used the wheel bearings? Am I being overly cautious? |
Krieger |
Jan 23 2013, 12:15 AM
Advanced Member Group: Members Posts: 4,754 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I've done it twice. I do not know about the bearing itself, but the seals get mangled.
McMark |
Jan 23 2013, 12:26 AM
I have to do it tomorrow. I'll take a video for you.
euro911 |
Jan 23 2013, 01:48 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I've only removed a set of rear hubs once to date. I had to beat the the hell out of them with several rests stops before they finally came out. Needless to say, the bearings were toast afterwards, however they were originals from 1971 (IMG:style_emoticons/default/confused24.gif)
Now, if you had a nice shop press ... (IMG:style_emoticons/default/laugh.gif) I wonder if stuffing the hubs with dry ice would shrink them enough to allow you to remove them without damaging the bearings? (IMG:style_emoticons/default/idea.gif) |
sean_v8_914 |
Jan 23 2013, 08:53 AM
i have saved parts for years thinking I had "the goods". ...until I went to use them.
I feel your pain |
Elliot Cannon |
Jan 23 2013, 12:40 PM
I've only removed a set of rear hubs once to date. I had to beat the the hell out of them with several rests stops before they finally came out. Needless to say, the bearings were toast afterwards, however they were originals from 1971 (IMG:style_emoticons/default/confused24.gif) Now, if you had a nice shop press ... (IMG:style_emoticons/default/laugh.gif) I wonder if stuffing the hubs with dry ice would shrink them enough to allow you to remove them without damaging the bearings? (IMG:style_emoticons/default/idea.gif) A shop press won't work to remove the hubs without putting huge stress on the bearings. The bad hub actually came out relatively easy so maybe the bearing is OK. Yeah right! (IMG:style_emoticons/default/av-943.gif) |
lagunero |
Jan 26 2013, 12:23 AM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
THOMAS says Hi
euro911 |
Jan 26 2013, 01:14 AM
Tell him to get his butt back on the board (IMG:style_emoticons/default/slap.gif)
Elliot Cannon |
Jan 26 2013, 12:26 PM
Elliot Cannon |
Jan 26 2013, 12:50 PM
Two more steps forward. Rear suspension done, 72mm wheel lugs installed. Waiting for rear rotors and front brakes. I sent Jeff at QRS pictures of the problems fitting up the fiberglass fenders. He sent me a message today saying, "it's a simple problem but difficult to explain". (IMG:style_emoticons/default/lol-2.gif) Possible one step back.
Attached image(s) |
Elliot Cannon |
Jan 28 2013, 08:13 PM
Just got the rear rotors. Still working to get the left rear fender fit up. Drilled some holes and "clecko'd" it today.
Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:52 AM |
