8" 951 Fuchs on a narrow body, Is it possible??? Pics and tire sizes requested!!! |
bigkensteele |
Feb 3 2013, 12:27 AM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I picked up a set of 951 Fuchs today, 7&8 x 16. They are ugly, which is fine by me as I would like to have them blasted and do an RSR finish.
Search tells me that they have been fit to narrow body cars, but I would like to know what must be done in the rear to make them fit. I would also appreciated pictures and get some insight on tire sizing as well as ideas for spacers for the front. Thanks, Ken |
Dave_Darling |
Feb 3 2013, 12:37 AM
914 Idiot Group: Members Posts: 15,060 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It can be tough to fit 7s under stock fenders. I think 8s would be impossible. Of course, tire sizes and alignment settings and the exact offset of the wheels make a difference, as well as individual chassis differences. So it's never quite safe to say "impossible"...
Be prepared to have to modify the rear fenders to at least some extent. They may need to be pulled or rolled outward, or possibly even cut and patched. --DD |
Mike Bellis |
Feb 3 2013, 12:49 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
bigkensteele |
Feb 3 2013, 12:54 AM
It can be tough to fit 7s under stock fenders. I think 8s would be impossible. Of course, tire sizes and alignment settings and the exact offset of the wheels make a difference, as well as individual chassis differences. So it's never quite safe to say "impossible"... Be prepared to have to modify the rear fenders to at least some extent. They may need to be pulled or rolled outward, or possibly even cut and patched. --DD Thanks, Dave. I probably should have stated that I am at a cross-road right now. I have AA repro flares. I have a set of 911 6&7 x 16 Fuchs as well as the 944 set. I can probably pull off whatever combination I want to try. However, I LOVE the look of HaroldD's car. If I could pull that off, I would probably sell the flares. |
Mike Bellis |
Feb 3 2013, 12:57 AM
bigkensteele |
Feb 3 2013, 01:05 AM
However, I LOVE the look of HaroldD's car. If I could pull that off, I would probably sell the flares. They look rolled it that pic... I have been told you can stretch them a full inch with the roller. That is the same guarantee I got when I bought that pump from the back-pages of Playboy! (IMG:style_emoticons/default/confused24.gif) |
sixnotfour |
Feb 3 2013, 01:58 AM
914 Wizard Group: Members Posts: 10,636 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Harold's 914-6 is awesome, but if lowered he would be rubbing, I had them on a 914 that was low , I started with 7's a bit of fender rolling with a 1x2 wood board, A while later switch to the 16x8 951's and had to go a bit more same method. I don't know if the roller would work as the rear fender is not a true radius.
Attached image(s) |
speed metal army |
Feb 3 2013, 02:04 AM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
sixnotfour |
Feb 3 2013, 02:22 AM
Finally found a pic of what it takes to run em, 245/45x16 951's, the burnt paint is from years of different wheel combos.
FYI my car now restored to stock. Attached image(s) |
sixnotfour |
Feb 3 2013, 03:23 AM
I made these for my sons Golf and I ended up with because he had to have 17's ???
16x6's widened to 7.5.. 1.5 inch added to the inside and a spacer.......7's would be perfect, Attached image(s) |
HaraldD |
Feb 3 2013, 06:49 AM
Member Group: Members Posts: 90 Joined: 23-November 08 From: Germany Member No.: 9,781 Region Association: Germany |
Hi,
here are 2 Fotos of my car. It is maybe 1 inch each side, but it`s enough. If you don`t know it - you don`t see it... (IMG:style_emoticons/default/smile.gif) Regards Harald |
914Sixer |
Feb 3 2013, 08:38 AM
914 Guru Group: Members Posts: 9,016 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
With the flares you can put 8" on each corner with no problem. I have even seen 9" on the rear with the right tire combo.
Woody |
Feb 3 2013, 12:18 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
With the flares you can put 8" on each corner with no problem. I have even seen 9" on the rear with the right tire combo. I'm running 10s (IMG:style_emoticons/default/poke.gif) |
carguy914 |
Feb 3 2013, 01:03 PM
Newbie Group: Members Posts: 34 Joined: 10-December 11 From: Mt Pleasant, SC Member No.: 13,883 Region Association: South East States |
The 951 Fuchs have a different offset and may work ok, (tire size is everything) if you notice the lug nut holes are recessed and the 7" wheel for the front look more like a 6" 911 wheel on the face, and the same for the rear 8"...looks more like a 7" 911 most of the extra width is on the backside...so it's back to some 914's will accept 911 7" at the rear and some won't and it crazy from side to side.
Spoke |
Jerry Group: Members Posts: 7,085 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
carr914 |
Feb 3 2013, 01:08 PM
Racer from Birth Group: Members Posts: 121,985 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
If you give up on the 8"s, let me know I need a set
brant |
Feb 3 2013, 01:23 PM
914 Wizard Group: Members Posts: 11,793 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
how wide are Harold's rear rims though?
here are 7inch fuchs with 911 offset (different offset) these have 1 inch spacers and still plenty of room I have test fit 8's on the car and honestly might be able to run 8's with some spacer but the fenders are VERY worked over and not stock at all: Attached image(s) |
brant |
Feb 3 2013, 01:24 PM
here are 6inch rims with no spacer as a test:
Attached image(s) |
brant |
and 7inch fuchs with no spacer:
Attached image(s) |
914Eric |
Feb 3 2013, 01:44 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 23rd November 2024 - 01:46 AM |
