914-4 rear brake caliper options? |
ETMracing |
Sep 23 2013, 11:24 AM
Newbie Group: Members Posts: 37 Joined: 22-August 13 From: frederick md Member No.: 16,288 Region Association: MidAtlantic Region |
Will be doing the BMW 320i front calipers on my 1970 914-4 2.0 but was wondering what can I use for a rear caliper? Thanks
type47 |
Sep 23 2013, 11:45 AM
http://www.pmbperformance.com/catalog.html
nice to support our vendors... + great products and tech advice |
Eric_Shea |
Sep 23 2013, 12:48 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Thanks Jim,
Here's the link to all of the 914 calipers: http://www.pmbperformance.com/914-brakes.html With the 48mm pistons and large pad up front the VB914-6 or a stock 914-6 rear caliper would be a perfect match bias and pad wise. This would give you a 38mm piston in the rear which would be the same as a 911RS, early 930, 911SC and 911 Carrera pad and piston size all around. Your bias would be 1.6:1 and perfect for what the factory established for the car. We have two pair of original -6 and -6/GT calipers for $1,200 and $1,500 respectively as well. |
pdlightning |
Sep 23 2013, 01:05 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
Thanks Jim, Here's the link to all of the 914 calipers: http://www.pmbperformance.com/914-brakes.html With the 48mm pistons and large pad up front the VB914-6 or a stock 914-6 rear caliper would be a perfect match bias and pad wise. This would give you a 38mm piston in the rear which would be the same as a 911RS, early 930, 911SC and 911 Carrera pad and piston size all around. Your bias would be 1.6:1 and perfect for what the factory established for the car. We have two pair of original -6 and -6/GT calipers for $1,200 and $1,500 respectively as well. ALL I can say is see Eric at http://www.pmbperformance.com/catalog.html I bought the rear 308/V brake set up from them and they are beautiful ! Nice and honest people and great products. Only place to go. Direct bolt up and Vented rotors along with parking brake retention! |
Lo-Fi Version | Time is now: 27th September 2024 - 08:38 AM |
