Should there be a screw here, Mounting lower dash |
PanelBilly |
Jan 26 2014, 06:49 PM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I had 914Rubber recover all my interior parts and I'm thinking there should be a screw in the lower dash on the side. Looks like I should cut the vinyl open, but I want to check before I cut. Could someone check and see if there's a black plastic plug in this place?
Attached thumbnail(s) |
bdstone914 |
Jan 26 2014, 06:53 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes there should be a screw in each end.
David_S |
Jan 26 2014, 06:58 PM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
Yep .... I looked at the lower dashes that I have and they all have a screw in about the location that I tried to circle.
PanelBilly |
Jan 26 2014, 07:01 PM
That would explain why I could get it to stay in place. I was using the vests to carry the load rather than screws.
mepstein |
Jan 26 2014, 07:19 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Screw and a plastic plug to cover the hole. The plug is like the ones on the targa bar pad but larger diameter.
Lo-Fi Version | Time is now: 27th September 2024 - 05:27 PM |
