fuel selection, What kind of gas? brand? octane? |
Carlitos Way |
Jan 3 2005, 03:53 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
I'm curious. I'm sure a lot of gas selection comes to personal preference, but I'm wondering what some of the engine builders and long-time techs recommend for the Type IV engines that we run. Would your selection depend on the year? (i.e. smog pump vs. no smog pump?) carbs vs. carbs? brand? octane? additives?
I'd love to hear what you guys have to say on the subject. Thanks, Carlos |
Dave_Darling |
Jan 3 2005, 04:52 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Depends on the exact engine. If you have a stock engine, follow Porsche's recommendation: Regular (87 US pump octane) for 1.8s and 2.0s; Super (91-93 US pump octane) for early 1.7s; Regular for at least some later 1.7s. (Euro 1.8s were spec'ed for Super; Euro 2.0s for mid-grade.) The "RON" or "ROZ" number listed in the book is about 4-5 points higher than the ratings you'll find on fuel pumps in the US.
If you have a modified motor, particularly if the compression and/or cam grind have been changed, then have a conversation with the engine builder about which type of fuel you should be running. For the most part, I feel that fuel brands are all but meaningless. I buy from "name" retailers, because I'm not sure how much I trust the "no-name" ones, but I'm not very picky about which "name" I use. --DD |
wilchek |
Jan 3 2005, 05:37 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Any idea about leaded gas. I live in PA, and have a place were people go to cruise their old cars. One of the gas stations still sells leaded gas. Try that one in Cali., you have to love PA, for ignoring emissions and the environment for the old cars.
Dave_Darling |
Jan 3 2005, 06:04 PM
You can use it if you like--as long as your car does not have a cataltytic converter. (Or an O2 sensor, which would be an aftermarket addition in a 914.) Unleaded is fine, too.
--DD |
IronHillRestorations |
Jan 3 2005, 06:07 PM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Generally speaking, use the LOWEST octane you can without pre-ignition, unless the car maker or engine builder says otherwise.
Higher octane fuels have more additives to make it burn slower. These additives can end up as carbon deposits in the combustion chamber (top of the piston, cylinder head, valves), and cause pre-ignition which can make an endless cycle; you have to use high octane because it pre-ignites and it also adds more carbon deposits. Using a fuel additive like the BG products, or Techron can help reduce combustion chamber deposits. Air cooled engines generally operated at higher temps than an engine with watercooled heads, so carbon deposit build up usually isn't as bad, but it can still happen. If you want to play Mr. Wizard, take a medicine dropper of regular gas, put the gas on a white plate and burn it. Do the same with high octane, and you'll find the high octane burns slower, has more sooty smoke, and leaves more residue. You'll find a side by side comparison of the two "burns" interesting. As far as leaded gas, I'd bet my money that is a urban myth. Last I heard "old style" leaded fuel is no longer in production, and it's against the law to sell it anywhere in the US. |
Mark Henry |
Jan 3 2005, 06:08 PM
What Dave said and if you use mid or premo buy it from a busy station.
Lo-Fi Version | Time is now: 27th September 2024 - 11:45 AM |
