Spark Plug Wires for 12mm Spark Plugs, 12mm Spark Plug Wires |
Highland |
May 31 2014, 07:23 PM
Senior Member Group: Members Posts: 526 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I had my 2.0 heads rebuilt for 12mm spark plugs but don't know where to buy ignition wires. I am using a stock distributer.
Recommendations would be appreciated. |
lonewolfe |
May 31 2014, 07:31 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
VaccaRabite |
May 31 2014, 08:01 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If using a stock dizzy, use stock wires.
IMO no need to use special wires unless you are using some sort of optical dizzy that needs the spiral wound wires. Zach |
McMark |
May 31 2014, 08:23 PM
Stock wires will work fine. If you want tight fitting boots, you can get wire ends from NGK in various angles. They just screw onto the wires (just like stock ends). You can even move the rubber washer/boots over to those ends, just like stock.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.vintagecb750.com-419-1401589420.1.jpg) More details in this PDF Catalog. |
boxsterfan |
May 31 2014, 09:29 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Lo-Fi Version | Time is now: 27th September 2024 - 04:35 PM |
