Magic trick for removing trans fill plug?, Its in there! |
speed metal army |
Aug 8 2014, 07:20 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Advice please! I know its a17mm hex etc, its just being stubborn as hell!
bulitt |
Aug 8 2014, 08:03 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Big heat!
injunmort |
Aug 8 2014, 08:04 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I agree , if it is that stuck
speed metal army |
Aug 8 2014, 08:36 PM
Heat the area surrounding the plug i assume?
injunmort |
Aug 8 2014, 08:47 PM
right on the plug
mepstein |
Aug 8 2014, 08:57 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lots of leverage
cpavlenko |
Aug 8 2014, 09:04 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
speed metal army |
Aug 8 2014, 09:11 PM
On the plug? This would expand the plug.. (IMG:style_emoticons/default/confused24.gif) But heck, if it works i'm in! (IMG:style_emoticons/default/chowtime.gif)
Mike Bellis |
Aug 8 2014, 09:29 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Allen key, 2x4 to hold the key down, 2 ratchet straps to keep the 2x4 from moving, long pipe to add leverage to the key.
speed metal army |
Aug 8 2014, 09:42 PM
Allen key, 2x4 to hold the key down, 2 ratchet straps to keep the 2x4 from moving, long pipe to add leverage to the key. Im going to need a sketch for the 2x4 part of this.. (IMG:style_emoticons/default/biggrin.gif) |
02loftsmoor |
Aug 8 2014, 09:51 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Wheaties (IMG:style_emoticons/default/poke.gif)
Elliot Cannon |
Aug 8 2014, 10:07 PM
Heat the plug and the area around it. Then while wearing a thick pair of gloves, stick an ice cube inside the plug. Use a small cheater bar (length of pipe) on the allen wrench and give it a try. Think about it first. Visualize the plug loosening. Keep a positive frame of mind. If that doesn't work, a long chain of expletives sometimes helps. (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/laugh.gif)
speed metal army |
Aug 8 2014, 10:14 PM
Heat the plug and the area around it. Then while wearing a thick pair of gloves, stick an ice cube inside the plug. Use a small cheater bar (length of pipe) on the allen wrench and give it a try. Think about it first. Visualize the plug loosening. Keep a positive frame of mind. If that doesn't work, a long chain of expletives sometimes helps. (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/laugh.gif) I like this one best.. Wish me luck! (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Aug 8 2014, 10:15 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Allen key, 2x4 to hold the key down, 2 ratchet straps to keep the 2x4 from moving, long pipe to add leverage to the key. Im going to need a sketch for the 2x4 part of this.. (IMG:style_emoticons/default/biggrin.gif) I think he is saying to strap the 2 x 4 to the trans to hold in the allen key. It is a shallow plug and the key can twist out under heavy pressure. |
speed metal army |
Aug 8 2014, 10:18 PM
Allen key, 2x4 to hold the key down, 2 ratchet straps to keep the 2x4 from moving, long pipe to add leverage to the key. Im going to need a sketch for the 2x4 part of this.. (IMG:style_emoticons/default/biggrin.gif) I think he is saying to strap the 2 x 4 to the trans to hold in the allen key. It is a shallow plug and the key can twist out under heavy pressure. This makes sense! I actually thought he was fuch'n with me a little. (IMG:style_emoticons/default/happy11.gif) |
Chris H. |
Aug 8 2014, 10:32 PM
Senior Member Group: Members Posts: 4,043 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Heat the plug and the area around it. Then while wearing a thick pair of gloves, stick an ice cube inside the plug. Use a small cheater bar (length of pipe) on the allen wrench and give it a try. Think about it first. Visualize the plug loosening. Keep a positive frame of mind. If that doesn't work, a long chain of expletives sometimes helps. (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/laugh.gif) Lawn chair...you forgot about the lawn chair. |
seareef228 |
Aug 8 2014, 11:40 PM
Newbie Group: Members Posts: 32 Joined: 13-May 14 From: so cal Member No.: 17,347 Region Association: None |
pb blaster over night
then use square tubing or a floor jack handle for a breraker bar should work if you are simi strong |
seareef228 |
Aug 8 2014, 11:46 PM
heat makes me nervous under a car but if you do, what you are doing is this,
heat it up right on the plug untill its red hot now heres the trick wait for it to cool for about 30seconds to 1 min the plug first expands then when it cools it contracts this is when you hit it hard |
euro911 |
Aug 8 2014, 11:57 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Also, don't fiddle around with an inexpensive (cheep) Allen wrench. Spend a little extra $ for a 1/2" breaker bar and the special Allen wrench socket. Snap-On sells the socket.
seareef228 |
Aug 9 2014, 12:10 AM
Also, don't fiddle around with an inexpensive (cheep) Allen wrench. Spend a little extra $ for a 1/2" breaker bar and the special Allen wrench socket. Snap-On sells the socket. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 05:30 AM |
