915 tranny Vs. 914 tranny, How similar? |
wrpspddrvr |
Jan 24 2005, 02:33 AM
Member Group: Members Posts: 333 Joined: 22-December 04 Member No.: 3,317 Region Association: None |
How similar is the 915 tranny and the tranny that comes on 914s? I don't guess we'd be lucky enough for, say, a PhantomGrip device that fits the 915 to fit the 914 tranny.....? http://www.phantomgrip.com/product_lists.p...hp?make=Porsche
Cole |
Brando |
Jan 24 2005, 03:04 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
915 vs 901 ... 901 can handle to about 280-300hp/torque. 915 can handle closer to 450-480hp/torque.
901 was used on late 60s to mid 70's (74-75) 911s and all 914s. It's a 5-speed aluminum-magnesium case. 5 speed + reverse. the 914 version had an 'odd' shift pattern and the lockout on 1st/reverse gears. the 911 version had a normal pattern and a lockout on 5th & reverse. The 915 trans was used on all 911s until, i think, the early 90's when the 993 came out (G50-50/tiptronic). all aluminum case. 5 speed + reverse. Same pattern as the 911-style 901 trans. Now, if you want cool... do a Sport-o-matic swap (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (oh yeah. I've been drinking, so the accuracy of ^ statements may not be 100% true. 50% true, even.) |
ArtechnikA |
Jan 24 2005, 06:22 AM
so - just for clarification, the shift pattern of a '914' 901 and a 911's 901/911 is identical. Porsche went to the 915 in 1972 with the 2,4 liter engine and kept it, through various internal redesigns, right through the 911SC. |
michel richard |
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I believe that the 901 had the same pattern on both 914 and 911. They were used on the 911 until the advent of the 2.4 emgome om 1972.
Michel Richard |
Jeroen |
Jan 24 2005, 06:32 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Geeezzz... you guys need to learn your donor cars (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
915 box was on the 911 from 72 through 86 (carrera 3.2) The G50 was introduced in '87 (still on the Carrera 3.2), was also used in the 964 (different version) and the 993 (6 speed) and even today's 996 GT3 Anyway... If I get your question right, you're asking if you can mount a 915 LSD in a 901/914 box From what I picked up from other discussions here on the BBS, the 915 diff comes in 2 types: with a fine spline and a coarse spline. One of those also fits the 901/914 box (can't remember which one) Try a search on LSD |
ClayPerrine |
Jan 24 2005, 07:27 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 901 and the early 915 both had coarse spline diffs and can use the same output flanges. But the diffs are not interchangable. Slightly different sized. |
Andyrew |
Jan 24 2005, 09:14 AM
No.... I see a G-50 for 350..... and a 915 for 350...
Choices.... Someone try it out!!!!! http://www.phantomgrip.com/product_lists.p...hp?make=Porsche Andrew |
ArtechnikA |
Jan 24 2005, 09:26 AM
hey - i didn't say it *stopped* with the SC, just that it was used through the SC. beyond that i wasn't sure. i get fuzzy on the new cars ... |
East coaster |
Jan 24 2005, 09:53 AM
Senior Member Group: Members Posts: 1,752 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
901 - it's in the car and works.
915 - you buy a used one, send it to HPH in Feb of 2004 for conversion for 914 use and you wait about a year and still don't see it! Sorry, just starting to get worried I'll never see my tranny again (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
machina |
Jan 24 2005, 10:07 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
isn't the 915 almost twice the weight of a 901?
dealbreaker IMO unless you have big torque requirements. |
Reiche |
Jan 24 2005, 10:38 AM
Member Group: Members Posts: 169 Joined: 13-October 04 From: Vista, CA Member No.: 2,934 |
'cuz the searches on alcohol obviously weren't working. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Jeroen |
Jan 24 2005, 11:09 AM
Thanks for clearing that up! |
John |
Jan 24 2005, 10:08 PM
Nope. |
lapuwali |
Jan 24 2005, 11:47 PM
A 914 'box is about 75lbs. I believe the 915 is about 125lbs. Not twice, but pretty close to twice.
John |
Jan 24 2005, 11:53 PM
Mine sure didn't feel like it weighed 125 lbs when I installed it. Heavier than a 901, but not that much more.
Hell my 930 trans didn't weigh much either. I lifted all of them by hand and lined up the clutch splines/input shaft splines alone. (so I kind of doubt 125lbs., but probably 100 at least.) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:19 AM |
