distributor questions, just found my spare is off 180 from the one in the car |
DRPHIL914 |
Nov 11 2014, 11:14 PM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
They are identical and have same numbers but this spare I bought that had been taken apart cleaned by a world member looks like brand new. BUT the rotor is aligned 180 degrees off for the other one when installed? Can this be changed?
If so , how? |
bdstone914 |
Nov 11 2014, 11:33 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Remove the part at the bottom of the shaft and rotate it 180.
Remove the spiral spring. Clamp the two nubs in a vice. Drive the pin out. Rotate the shaft 180. Reassemble. |
dknechtly |
Nov 12 2014, 11:22 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
Hmmm... don't you just need to take the dist out, rotate it 180 and put it back in?
Cap'n Krusty |
Nov 12 2014, 12:23 PM
No clearance for the vacuum capsule. Do it right, do it once.
The Cap'n |
dknechtly |
Nov 13 2014, 08:26 AM
I went home last and double checked the bottom of the distributor and the top of the drive... sure enough, the tabs are slightly off center (so it only goes in one way). I always thought it could go in either way! Always something new with these 914's.
Lo-Fi Version | Time is now: 27th September 2024 - 08:41 AM |
