New GB late airbox grill and new Gasket,, $34 for Both --- Add the airbox rebuild kit for $14 Who's in? |
Mikey914 |
Dec 10 2014, 08:57 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We just finished the mold for the grills on the late air box and they look just like factory (less the over spray). The grills have been harder to find in good condition but now you can get one NEW!
No new grill would be complete without a new seal to hold it into place. We didn't just phone this one in. Other seals use an extruded strip of rubber and notch the corners to make a rectangle to hold the grill and slide over the top of the air box. We molded a seal to fit the air box perfectly. We also made it out of silicone to make a good seal. Not just a fin or flap, but a little over 1/4" flat seal all the way around. The real beauty of this seal is that when it is installed it will actually force the grill to sit about 1/16" below the body grill. These will be about $25 each for the seal and the same for the grill after the GB is over. It's also a good time to re seal the flapper valved in the air box, so if you want to add that in, it has been discounted to make this project more complete. Attached thumbnail(s) Attached image(s) |
Mikey914 |
Dec 10 2014, 08:58 PM
Here's a better look at the offset
Attached thumbnail(s) |
JmuRiz |
Dec 10 2014, 09:11 PM
914 Guru Group: Members Posts: 5,489 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
You suck, making me want to spend more money. I don't have a screen on my car, but always thought they were a good idea.
914_teener |
Dec 10 2014, 09:38 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Mark,
I stand to be edfucated. Was there a factory grille for the early cars? Currently my car has none and the fresh air motor is frozen and needs restoration. When I say early I mean up to 73. So late means 74 on up? I didn't know the air boxes were different. |
dlkawashima |
Dec 10 2014, 10:59 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
My late '73, build date 6/73, has the grille.
Count me in for a grille and seal. |
G e o r g e |
Dec 11 2014, 12:47 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
Can I add it to my order from earlier today?
Mikey914 |
Dec 11 2014, 01:48 AM
Harpo |
Dec 11 2014, 03:43 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Sign me up
David |
dlee6204 |
Dec 11 2014, 07:13 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm in for all three.
McMark |
Dec 11 2014, 07:23 AM
Oh hell yes!
G e o r g e |
Dec 11 2014, 03:09 PM
warrenoliver |
Dec 11 2014, 04:49 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
My '73 does not have a grill (I assume this is fitted under the cowl). I did not know one was available but it certainly needs one to keep the crap out of the airbox and to keep it from eventually blowing leaves and other junk into the car.
Do I have to remove the airbox in order to install this? Any pics of a car with this installed? |
Mikey914 |
Dec 11 2014, 05:05 PM
The airbox will need to cone out, and there have been son good write ups on this. The key is labeled wires so you know has to put it back together.
A VERY good time to check the motor on the blower and replace some flapper seals Mark |
mharmon |
Dec 11 2014, 07:02 PM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
I'm in for 2 sets
914werke |
Dec 11 2014, 07:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,542 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
whats this rebuild kit?
Mikey914 |
Dec 11 2014, 07:27 PM
Its the 2 flapper seals and the main motor and upper box seal.
warrenoliver |
Dec 12 2014, 10:43 AM
The airbox will need to cone out, and there have been son good write ups on this. The key is labeled wires so you know has to put it back together. A VERY good time to check the motor on the blower and replace some flapper seals Mark Shucks! I was hoping you had a magic way of installing these without removing the tank and airbox. (IMG:style_emoticons/default/blink.gif) Regardless, I am in for one if it fits my '73. How do I tell? |
bigkensteele |
Dec 12 2014, 06:18 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I'm in for both as well as however many flapper seals are in the box. Is it more than 1?
jack20 |
Dec 12 2014, 07:16 PM
Member Group: Members Posts: 412 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Mark,
As a newbie this my first GB so just let me know what to do. I'm a current customer. I'm in for the 3 piece set. Jack |
mapguy |
Dec 12 2014, 07:34 PM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
Take my money!!!
I'm in for one set of all 3 bits. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:35 AM |
