Engine out!, finally |
JerryP |
Mar 21 2005, 07:33 AM
member Group: Members Posts: 314 Joined: 8-October 03 From: Berwyn, PA Member No.: 1,225 |
Due to the most stubborn bolt I've ever come across and the flu running rampant through my house, it took me an extra weekend. Thanks to Rich(Artechnika) and Skline who offered to come out and help....but reading how all you guys drop your engines in 30 minutes, I really wanted to do it myself (except of course for all the online coaching I needed) no matter how long it took.
I can see what you all mean. Next time will be much smoother. Attached image(s) |
JerryP |
Mar 21 2005, 07:35 AM
bought this as a parts car but it's actually not as bad off as I originally thought.
Attached image(s) |
JerryP |
Mar 21 2005, 07:36 AM
woohoo!
Attached image(s) |
JerryP |
Mar 21 2005, 07:39 AM
sat in a dirty garge for 10 years.....unbelievable amount of crud. After I got it out I found out I need to get the heat exchangers off to use on my other car. Would it be easier to raise the thing up somehow?
Attached image(s) |
machina |
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
I had some bolts like that as well. Ended up using a sledge hammer and a 2x4. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
It's great though when everything is back together, all the nuts and bolts are shiny and new and nothing is stuck and or rusted together (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Not to mention how easy it is to work on the motor whithout 30 years of dirt and grime in your face. |
machina |
Mar 21 2005, 07:40 AM
If the oil is out, tip the thing up on its nose. |
TheCabinetmaker |
Mar 21 2005, 07:44 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
if you tip it on its front, remove the tranni first. The oil will run out the vent hole and make a hell of a mess. Ask me how I know. |
machina |
Mar 21 2005, 07:46 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) how do you know? anyway, just plug it. |
JerryP |
Mar 21 2005, 07:56 AM
Oil is all drained out. I thought all the gas was drained out also until I had to move the fuel pump to get at the nut on top of the engine mount bar. Good thing I don't smoke.
After reading all the threads about the studs breaking off, I just want as much access and leverage as possible. I've been soaking the nuts with PB Blaster for a couple days. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:26 AM |
