911 front hub seal, which way is right? |
Olympic 914 |
Mar 2 2016, 07:17 PM
Group: Members Posts: 1,699 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
installed the hub bearing seals today and after installing the one pictured at left I noticed the difference.
I think the one on the right is the correct orientation. i.e. gold to the inside. but not really sure. I am probably stuck getting a new seal unless anyone knows a trick to get one out without destroying it. close-up pictures. you can see the lip in these pics. on the gold side the lip protrudes. |
914Sixer |
Mar 2 2016, 07:37 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Rubber out. You will probably destroy it taking it out.
Olympic 914 |
Mar 2 2016, 07:59 PM
Rubber out. You will probably destroy it taking it out. Damn.... So the first one I installed was correct.. Then I over thought the situation and installed the second one wrong. (IMG:style_emoticons/default/headbang.gif) Now to source another seal, hope I can find one locally. I don't like to pay $7-$9 shipping on a $4 part. |
914Sixer |
Mar 2 2016, 08:06 PM
Should be able to pick one up at your local parts house.
somd914 |
Mar 2 2016, 09:38 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I was pleasantly surprised to find seals and bearings at and an assortment of FLAPS.
brant |
Mar 2 2016, 10:42 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I reuse them about 3 times on average
Take it out from the front, through the hub It's not hard to get them out in good shape (We do bearing checks pretty often on the race car) |
6freak |
Mar 3 2016, 03:20 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
yard the bitch out and go get a new one ,I would`nt even take a chance for $5.00! and your times worth more than that JMO good luck
(IMG:style_emoticons/default/smile.gif) |
Olympic 914 |
Mar 3 2016, 06:40 PM
yard the bitch out and go get a new one ,I would`nt even take a chance for $5.00! and your times worth more than that JMO good luck (IMG:style_emoticons/default/smile.gif) Yeah.. Did it today. spent a bunch of time hunting one down. no good at any locals auto parts. found one 26 miles away. went and got it. So now I have a elring on one side and a Timken on the other. it'll work.. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:36 PM |
