WTB: thermostat bellows, best source currently? |
oakdalecurtis |
Sep 1 2016, 11:36 AM
Oakdalecurtis Group: Members Posts: 1,336 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
rmdinmd |
Sep 1 2016, 11:45 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
You can try these guys for a new one. http://awesomepowdercoat.com/thermostat_ne...ed_rebuilt.html
Am sure there are used ones available on world also. |
oakdalecurtis |
Sep 1 2016, 11:55 AM
You can try these guys for a new one. http://awesomepowdercoat.com/thermostat_ne...ed_rebuilt.html Am sure there are used ones available on world also. Thanks Rmdin, saw those, AA has new ones for less than the even awesome's refurbs, but AA's are slightly different, George said modifications are slight and easy to make work, anyone know? |
mark04usa |
Sep 1 2016, 12:58 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
There is one important difference between the two thermostats. The original (and the Awesome Powdercoat replacement) are fail-safe. If the part fails, it will typically then allow full cooling but will no longer close the flaps for warm-up. If the AA style replacement fails, it will fail in restricted cooling, warm-up mode, which could result in costly overheating (IMG:style_emoticons/default/headbang.gif)
Amphicar770 |
Sep 1 2016, 01:00 PM
Senior Member Group: Members Posts: 1,205 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I have one from awesome powdercoat. Works great, fits just like the original. Don't forget the new wire and (if you need it) the pulley.
914Sixer |
Sep 1 2016, 01:58 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Made in the USA ones on Ebay $129
oakdalecurtis |
Sep 1 2016, 02:43 PM
There is one important difference between the two thermostats. The original (and the Awesome Powdercoat replacement) are fail-safe. If the part fails, it will typically then allow full cooling but will no longer close the flaps for warm-up. If the AA style replacement fails, it will fail in restricted cooling, warm-up mode, which could result in costly overheating (IMG:style_emoticons/default/headbang.gif) Thanks for letting me know about the fail condition, that's a big deal and a no go on AA thermostat! |
Optimusglen |
Sep 1 2016, 03:08 PM
Senior Member Group: Members Posts: 919 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
It's worth noting that I haven't actually seen a new style fail. Anyone else hear of one failing yet?
Lo-Fi Version | Time is now: 27th September 2024 - 09:35 AM |
