Wanted - Riviera wheel, Need used Riviera wheel with 3.25 center. |
Darkkerry |
Oct 20 2016, 10:20 PM
I'm new here ... Group: Members Posts: 0 Joined: 11-September 16 From: Vancouver, WA Member No.: 20,386 Region Association: None |
Just had my 75's Riviera's stripped for polishing and discovered major cracks on one...can't relax and drive it that way. I need a used one to replace it. Thanks. Should be able to fit 195 15s (3.25 center opening...5.5 rim width).
MikeInMunich |
Oct 21 2016, 01:51 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Just had my 75's Riviera's stripped for polishing and discovered major cracks on one...can't relax and drive it that way. I need a used one to replace it. Thanks. Should be able to fit 195 15s (3.25 center opening...5.5 rim width). I have a set in Kileen TX. PM me if you're interested. Thanks, M.i.M. |
rhodyguy |
Oct 21 2016, 09:50 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
width-5.5"
bs-4" center hole-3" or so, tape is angled. Attached thumbnail(s) |
Tom_T |
Oct 21 2016, 10:42 AM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Just had my 75's Riviera's stripped for polishing and discovered major cracks on one...can't relax and drive it that way. I need a used one to replace it. Thanks. Should be able to fit 195 15s (3.25 center opening...5.5 rim width). Hey Kerry, You should post pix of your wheels to determine if they're the original Rivs with the flat outer rim (like in Rhodyguy's pix shown above), or the later repops with edge lip for mounting clamp-on balancing weights. Otherwise you could end up with a mismatched set. Original Riviera's came with the 914 ET40 offset, in addition to the VW Bug offset, but I'm not sure that all of the later Riv repops came in ET40 too. You'll want to match the offset of your current Rivs, which is what Rhody is trying to show you with the tape measured pix. Hope this helps. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Darkkerry |
Oct 21 2016, 11:05 AM
Thanks Tom. We are good. I've confirmed measures and rim with Rhodyguy. Glad to have found one. As you say, there are lots of repops that won't work...a rim jungle out there when searching for these older Rivieras.
Darkkerry |
Nov 5 2016, 09:21 AM
rhodyguy |
Nov 21 2016, 02:34 PM
sending pm.
rhodyguy |
Dec 6 2016, 01:54 PM
do the HE muffler ends look like this?
ndfrigi |
Dec 6 2016, 02:15 PM
Advanced Member Group: Members Posts: 2,953 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Darkkerry |
Dec 6 2016, 02:33 PM
Lo-Fi Version | Time is now: 27th September 2024 - 06:28 AM |
