CHT sensor extension, Curious, does it work? Who uses one? |
malcolm2 |
Oct 25 2016, 09:11 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I want to cover all my bases here. I have purchased the new GB CHT sensor from 914Rubber to try.
So, I think I will buy a spacer from Brad Mayeur to have the option. From what he says it should: "Porsche 914/4 Cylinder Head Temperature Sensor Extension. This little device slows down the heating of the sensor and improves warm up drivability." I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif) 914LTD.com Also found on RATWELL (scroll down to WORKAROUNDS)http://www.ratwell.com/technical/TempSensorII.html#parts |
bretth |
Oct 25 2016, 09:22 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
If I understand it correctly it is meant to keep the engine running a little richer for a longer period of time allowing for the extra cold engine assist until the engine is truly warm enough to run fine without it.
Mikey914 |
Oct 25 2016, 09:26 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Exactly. I have one also and may reproduce these.
BeatNavy |
Oct 25 2016, 09:28 AM
Certified Professional Scapegoat Group: Members Posts: 2,933 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif) Not sure what you're saying here. What the spacer does is increase the amount of time for the CHT to go from cold/cool (when the ECU richens the mixture to compensate for cold engine) to warm/hot when the engine can run effectively on a leaner mixture. If you're having low idle while cool I'd suspect something else, like an AAR that's not operating properly. I use one of Brad's spacers. My cold engine driving is good. The possible downside, which is probably attributable to or at least aggravated by the spacer, is the warm-start over rich condition. If I stop for an errand and then restart the car, the engine idles low to the point of almost dying for about 30 seconds. It's caused by the CHT cooling down faster than the engine and running too-rich. Funny, though, my A/F ratios don't look especially rich during the period that occurs. I'm looking at other potential root causes or ways to mitigate. I may remove the spacer for a few weeks to see how things run without it. |
malcolm2 |
Oct 25 2016, 09:36 AM
I have checked what I understand to be the other culprits.
So as I thought, this gizmo SLOWS the warming? And as you have noticed, it SPEEDS the cooling, when the engine is turned off? Everything that I have read just says it IMPROVES. So I was hoping for an IMPROVEMENT. |
BeatNavy |
Oct 25 2016, 09:45 AM
It doesn't slow down the engine warming. It slows down the CHT warming, which then signals to the ECU to keep the mixture richer, longer. A cold engine needs a richer mixture. The flip side to this is that the CHT then cools down faster with the engine off. It does this anyway because the heads are different material than the case, so to some degree this happens anyway. The effect is that after starting a warm car, a cool or cooler CHT will cause the ECU to make the mixture a little richer than it should be, resulting in a low idle until things "even out" again.
The spacer probably aggravates that a bit. Again, it does improve cold drivability (I believe, based on my experience). It probably aggravates the issue of warm-start over rich at least a bit. |
pbanders |
Oct 25 2016, 04:19 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
OK, I have one of these and have been using it for a while. It definitely does help keep the car richer for longer during warm-up, and helps keep the idle good even after the AAR has closed and the car is still warming up. That's the good part. The bad part is that when you stop the engine, and go into Target for 30 minutes, it causes the CHT to cool off faster than if it were directly connected to the head. Since D-Jet 914's already have a hot start problem due to the differential cooling of the aluminum heads as compared to the iron cylinder sleeves (making the mixture too rich), this additional cooling makes it even worse. So you're trading one driveability problem for another.
The "solution" (which doesn't exist) is to have a properly-curved CHT that's directly attached to the iron cylinder sleeve. Or, maybe some other clever thing. IMO, it's just something we live with owning a 45-year-old car. I'm on the fence about taking it out the next time I have a chance. Fact is any time I drive the car, it's got to go through the warm-up phase, and this spacer does help, whereas I don't always take a 15-30 minute break on every drive, so I'll probably keep it installed. BTW, when you have the "rich hot-start" problem, the solution is more air without more fuel. Here's what I do: with the key off, open the throttle about 1/4 to 1/3, then start the car. You don't want to turn the key and press the throttle down, because the "accelerator pump" action of the TPS will dump even more gas in. Immediately back off the throttle to keep the revs down when it starts. The additional air from the open throttle will start the car quickly, and the slight fouling of the plugs from the extra fuel will go away rapidly as you drive. |
pbanders |
Oct 25 2016, 04:22 PM
The possible downside, which is probably attributable to or at least aggravated by the spacer, is the warm-start over rich condition. If I stop for an errand and then restart the car, the engine idles low to the point of almost dying for about 30 seconds. It's caused by the CHT cooling down faster than the engine and running too-rich. Funny, though, my A/F ratios don't look especially rich during the period that occurs. I'm looking at other potential root causes or ways to mitigate. I may remove the spacer for a few weeks to see how things run without it. I didn't see your comment until I made mine, looks like we both came to the same conclusion. Try the method of hot starting that I suggested and see if it helps. If you come up with another explanation for this behavior and a fix make sure to post it. |
BeatNavy |
Oct 25 2016, 05:39 PM
The possible downside, which is probably attributable to or at least aggravated by the spacer, is the warm-start over rich condition. If I stop for an errand and then restart the car, the engine idles low to the point of almost dying for about 30 seconds. It's caused by the CHT cooling down faster than the engine and running too-rich. Funny, though, my A/F ratios don't look especially rich during the period that occurs. I'm looking at other potential root causes or ways to mitigate. I may remove the spacer for a few weeks to see how things run without it. I didn't see your comment until I made mine, looks like we both came to the same conclusion. Try the method of hot starting that I suggested and see if it helps. If you come up with another explanation for this behavior and a fix make sure to post it. All good, Brad. 80% of what I know about D-Jet I learned by reading your website anyway (IMG:style_emoticons/default/biggrin.gif) I will try your hot start method. Good to see you active here. |
pbanders |
Oct 25 2016, 06:15 PM
The possible downside, which is probably attributable to or at least aggravated by the spacer, is the warm-start over rich condition. If I stop for an errand and then restart the car, the engine idles low to the point of almost dying for about 30 seconds. It's caused by the CHT cooling down faster than the engine and running too-rich. Funny, though, my A/F ratios don't look especially rich during the period that occurs. I'm looking at other potential root causes or ways to mitigate. I may remove the spacer for a few weeks to see how things run without it. I didn't see your comment until I made mine, looks like we both came to the same conclusion. Try the method of hot starting that I suggested and see if it helps. If you come up with another explanation for this behavior and a fix make sure to post it. All good, Brad. 80% of what I know about D-Jet I learned by reading your website anyway (IMG:style_emoticons/default/biggrin.gif) I will try your hot start method. Good to see you active here. Don't open the throttle too much, all it needs is about 1/4 open or so, and be ready to back off, the revs come up quickly. What makes the hot start problem even worse is that if you start the car normally, i.e. with the throttle closed, and it's too rich, then it doesn't want to start at all until you open the throttle - but, when you do so, you squirt a ton more gas into it, making it even richer. If it has more air and you back off once it starts, without goosing it, it'll burn off the excess gas and heat up quickly. Unfortunate that this system wasn't engineered properly from the beginning. |
malcolm2 |
Oct 25 2016, 06:52 PM
From this and other research it seems that I may just have to continue to drive heel-toe out of the neighborhood until 250*F CHT. If thst is the worst thing I have to deal with, I guess I will deal. Not sure the wife and kids will understand how to make it work, but I can deal with the too.
TX914 |
Oct 26 2016, 06:13 AM
Alan-B Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
I wish some clever guru would create a way to modify the CHT signal (from within the car) to compensate for the too rich restart condition. Maybe a variable resistor?
My 2.0 D-Jet runs like a champ on a cool, low humidity day, but idle is too low when restarting on a hot, humid day. I have not tried pbanders’ method for restarting… but that sounds like a good suggestion. |
BeatNavy |
Oct 26 2016, 06:47 AM
I wish some clever guru would create a way to modify the CHT signal (from within the car) to compensate for the too rich restart condition. Maybe a variable resistor? My 2.0 D-Jet runs like a champ on a cool, low humidity day, but idle is too low when restarting on a hot, humid day. I have not tried pbanders’ method for restarting… but that sounds like a good suggestion. Some people have used or do use a variable resistor. Can't tell you off the top of my head who, but someone will know. I'd like to see how they set that up and maybe it will end up on my "to do" list (which never seems to get any shorter..... (IMG:style_emoticons/default/dry.gif) ) From this and other research it seems that I may just have to continue to drive heel-toe out of the neighborhood until 250*F CHT. If thst is the worst thing I have to deal with, I guess I will deal. Not sure the wife and kids will understand how to make it work, but I can deal with the too. Malcolm - I'm given to believe you shouldn't have to do this. If you think you've checked all the other D-Jet suspects / tuning, give the spacer a try and decide what works best: better warm-up performance or slightly more difficult warm-start idling. If you do get the spacer and the warm-up is still painful, you know you've got other things going on... |
DRPHIL914 |
Oct 26 2016, 07:15 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i have dealt with same issue with my 2.0 d-jet that BeatNavy has described - the issue of the hot start idle too low when restarting the car after being warmed up but off lfor a short run into the store or something of that sort. -
I did get a pot(potentiometer) that was a 0-1kohm that I put in line with the CHT circuit and was able to adjust that to a point where it added enough resistance that this was almost eliminated. but since I replaced the CHT with a new one I had laying around this seemed a lot less and I removed it - I might put it back, because the problem while there isn't as bad with this CHT - you can fool around with other things to lean out the A/F on start up and idle but I don't think that is the way to go . anyway its not hard to put together a variable resistor in line with the CHT- wondering what you think of this Mr. Anders.... (IMG:style_emoticons/default/popcorn[1].gif) |
Mikey914 |
Oct 26 2016, 10:20 AM
Well a rheostat would give you the ability to have a more precise adjustment, you are still working off your base measurement.
The real issue here is exactly what you did. "I replaced it with another I had lying around it it was better" So either one was bad, or incorrect. The real issue is that you don't want to be too lean on the hot side. This is what the additional resistor in the 73 did with the unit used on it. Why they decided to change the set up only the Germans know, but you could achieve the same thing by adding a small resistor in line 100ohm? The real question is would you want to put a 1000-2000 ohm rheostat in line to allow you to make the mixture richer? |
pbanders |
Oct 26 2016, 01:42 PM
i have dealt with same issue with my 2.0 d-jet that BeatNavy has described - the issue of the hot start idle too low when restarting the car after being warmed up but off lfor a short run into the store or something of that sort. - I did get a pot(potentiometer) that was a 0-1kohm that I put in line with the CHT circuit and was able to adjust that to a point where it added enough resistance that this was almost eliminated. but since I replaced the CHT with a new one I had laying around this seemed a lot less and I removed it - I might put it back, because the problem while there isn't as bad with this CHT - you can fool around with other things to lean out the A/F on start up and idle but I don't think that is the way to go . anyway its not hard to put together a variable resistor in line with the CHT- wondering what you think of this Mr. Anders.... (IMG:style_emoticons/default/popcorn[1].gif) EDITED response: This is what I get when I post too late at night and after my third glass of wine. The effect of CHT resistance on mixture is the higher the resistance, the richer the mixture. If you ADD resistance inline to the CHT, you're just going to make the mixture even richer and make it worse! What you want to do is add resistance in parallel to the CHT, which will have the effect of LOWERING the resistance the ECU sees, and making the mixture leaner. I'll put up a circuit for how to make a switchbox to do this using a potentiometer and a DPDT switch. |
pbanders |
Oct 28 2016, 04:32 PM
See my edited response above.
BTW, it's nearly 100 deg. F here today, gotta love late October in Phoenix. I was out doing some errands, and I drove the 914, so I got several chances to try different hot start techniques. What worked best was to start with key off, then slightly crack open the throttle 1/4 of the way or less. Turn the key and crank, and hold the throttle steady until it starts, then back off slightly to keep the revs from going up too much. Now, hold the throttle at 2000 rpm for about 20 seconds to clear the plugs and get the heads warming up. Now, slowly close the throttle until you reach idle, it should be reasonably stable. If it ever cools off, I'll make the switchbox I describe in the posting above. With a more complex switching arrangement, you could make the box capable of lean or rich mixture. |
913B |
Oct 28 2016, 04:46 PM
Senior Member Group: Members Posts: 851 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
I will have to keep you all's suggestions in mind next time I drive.
I was just happy I didnt have the erractic idle after I installed the CHT and ext. Its been a while since I drove mines. (IMG:style_emoticons/default/sad.gif) |
BeatNavy |
What worked best was to start with key off, then slightly crack open the throttle 1/4 of the way or less. Turn the key and crank, and hold the throttle steady until it starts, then back off slightly to keep the revs from going up too much. Now, hold the throttle at 2000 rpm for about 20 seconds to clear the plugs and get the heads warming up. Now, slowly close the throttle until you reach idle, it should be reasonably stable. If it ever cools off, I'll make the switchbox I describe in the posting above. With a more complex switching arrangement, you could make the box capable of lean or rich mixture. Did that exact technique this afternoon after filling up at the gas station, Brad. Started like a champ, and I sort of feathered the throttle for about 30 seconds until idle stabilized. It's manageable....just slightly annoying. EDITED response: This is what I get when I post too late at night and after my third glass of wine. The effect of CHT resistance on mixture is the higher the resistance, the richer the mixture. If you ADD resistance inline to the CHT, you're just going to make the mixture even richer and make it worse! What you want to do is add resistance in parallel to the CHT, which will have the effect of LOWERING the resistance the ECU sees, and making the mixture leaner. I'm glad I'm not the only one here who enjoys a second, or, ahem (IMG:style_emoticons/default/shades.gif) , third, glass of wine while hanging out here (IMG:style_emoticons/default/smile.gif) I was wondering if there was some way to meter more air in during the warm start process - almost like creating a temporary vacuum leak during the 30 seconds after warm start, as with the AAR at cold start. |
pbanders |
Oct 28 2016, 05:59 PM
What worked best was to start with key off, then slightly crack open the throttle 1/4 of the way or less. Turn the key and crank, and hold the throttle steady until it starts, then back off slightly to keep the revs from going up too much. Now, hold the throttle at 2000 rpm for about 20 seconds to clear the plugs and get the heads warming up. Now, slowly close the throttle until you reach idle, it should be reasonably stable. If it ever cools off, I'll make the switchbox I describe in the posting above. With a more complex switching arrangement, you could make the box capable of lean or rich mixture. Did that exact technique this afternoon after filling up at the gas station, Brad. Started like a champ, and I sort of feathered the throttle for about 30 seconds until idle stabilized. It's manageable....just slightly annoying. EDITED response: This is what I get when I post too late at night and after my third glass of wine. The effect of CHT resistance on mixture is the higher the resistance, the richer the mixture. If you ADD resistance inline to the CHT, you're just going to make the mixture even richer and make it worse! What you want to do is add resistance in parallel to the CHT, which will have the effect of LOWERING the resistance the ECU sees, and making the mixture leaner. I'm glad I'm not the only one here who enjoys a second, or, ahem (IMG:style_emoticons/default/shades.gif) , third, glass of wine while hanging out here (IMG:style_emoticons/default/smile.gif) I was wondering if there was some way to meter more air in during the warm start process - almost like creating a temporary vacuum leak during the 30 seconds after warm start, as with the AAR at cold start. You could do that, but if you're got something that can do that, like a solenoid-controlled air bleed, if you did it right, it could be the basis for an idle stabilizer, too. I'd eventually like to poke around and see if there's something out there that I can find, or maybe adapt an existing idle stabilizer to our cars. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:18 PM |
