914 Door Panels, Weather Stripping Mylar??? |
dilde |
May 4 2005, 12:07 AM
Newbie Group: Members Posts: 33 Joined: 29-March 05 From: Los Angeles, CA Member No.: 3,843 |
Okay guys, next question. So far, the responses have been outstanding.
My '73 2.0 is coming back from paint. All "fuzzy" stripping has been replaced in the doors. Problem: The painter has destroyed the clear plastic "mylar", or whatever, that is glued to the inside of the door, before you punch the panels in. Any suggestions? Is the stuff necessary? For sound? For water? Can I still buy it? Can I fabricate it? Etc. I have time and money. Just looking for the easiest and best way. Thanks in advance. Scott |
Dr Evil |
May 4 2005, 12:10 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Use a plastic trash bag and spray adhesive. They are needed to keep your wooden interior panels from warping when the rain seeps in.
HTH |
larryp |
May 4 2005, 06:14 AM
Member Group: Members Posts: 311 Joined: 9-May 03 From: Greenwich CT Member No.: 675 |
Even better, use the acoustic door mat. It is just as waterproof and makes the car a bunch quieter.
Door Mat |
CptTripps |
May 4 2005, 07:16 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Its not clear, but go get a roll of 'Contractor Bags' from Lowes/Home Depot. They are the same thickness, LOTS cheaper, and the size of the bag is big enough that it'll cover the whole panel.
Marlow |
May 4 2005, 07:33 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
I made mine out of drop-cloth plastic. Went to Home Depot and found the thickest I could (6 mil I think) then traced and cut it out. Used the rest of the dropcloth plastic to do a bunch of painting so no waste!
rhodyguy |
May 4 2005, 08:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
3M double sided, Scotch Tape works great (plenty cheap too). put it around perimeter. as stated, a piece of 1 or 2 mil plastic painter's drop cut roughly oversize. put it on from top to bottom, make a small x to go over the winder stem, and trim with a sharp razor knife or exacto. done!
k |
rhilgers |
May 4 2005, 11:32 AM
Member Group: Members Posts: 75 Joined: 17-July 03 From: Santa Clara CA Member No.: 919 |
A trick from the only crowd cheaper...vw bugs.
Use Tyvek tape to tape down the plastic. Ya know, Tyvek is the water barrior stuff for houses. They make their own tape for the seams. Waterproof, sticks like mad. I made the mistake of putting it down flat on carpet. Just the sides of the tape lifted the carpet up. About $10 at a good construction supplier. Side notes: Replace the fuzzy circular seals around the window knob with the fuzzy seperators found in 100 packs of CD/DVDs. Spray the back of the doorpanels with Scotchgard. -Rich Hilgersom |
Lo-Fi Version | Time is now: 27th September 2024 - 06:23 AM |
