Part ID |
Part ID |
litesonic |
May 5 2017, 09:31 PM
Newbie Group: Members Posts: 17 Joined: 8-January 15 From: Fort Collins CO Member No.: 18,307 Region Association: None |
So I humbly ask the collective wisdom of this board... what is this?
I have a non-start issue now (fuel pump runs, have full battery, lights on dash come on) she won't try to turn over. This car has been converted to carbs and still uses points. She shook pretty dramatically while idling (motor mounts are up for replacement). Perhaps this fell off? thanks in advance. |
914Sixer |
May 6 2017, 06:40 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Head light piviot
litesonic |
May 6 2017, 06:54 AM
Yep.
Which explains the overspray. I replaced a headlight housing and this was a left over part that must have fallen under the car. Bummer as that obviously has nothing to do with my no start issue. Thanks! |
cwpeden |
May 6 2017, 11:10 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Could be. If you didn't top up the headlight fluid the car wont start...for safety reasons.
Check your grounds. Rear trans to body Battery to body Relay board to body Dash to body Headlights to body and one more I cant remember When you are drawing enough amps to start the car it needs a complete circuit. |
litesonic |
May 6 2017, 04:45 PM
Could be. If you didn't top up the headlight fluid the car wont start...for safety reasons. Check your grounds. Rear trans to body Battery to body Relay board to body Dash to body Headlights to body and one more I cant remember When you are drawing enough amps to start the car it needs a complete circuit. Thanks... I needed the laugh about the headlight (and blinker) fluid. From another site: These cars often test us to see if we are worthy of ownership" |
whitetwinturbo |
May 6 2017, 10:39 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
...........just like Stone beer [you may NOT be worthy] (IMG:style_emoticons/default/beer3.gif)
porschetub |
May 7 2017, 12:32 AM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Tell me about it (IMG:style_emoticons/default/WTF.gif) ,went out to the car with an hour to spare and the previously good electrics went (IMG:style_emoticons/default/barf.gif) and I lost wipers and LH side park light....at least the six still makes that screaming noise (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) .
You have to laugh or you would go freakin nuts (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/wacko.gif) . |
cwpeden |
May 7 2017, 01:04 AM
I forgot to ask, which headlight pivot?? Never seen one like that
litesonic |
May 7 2017, 11:25 AM
Lo-Fi Version | Time is now: 27th September 2024 - 12:08 PM |
