transmission output shafts |
JFG |
Jun 21 2017, 01:06 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I'm onto the gearbox now that the engine is back together.
I have new output shaft seals but i thought there were holes to put a bar through in order to lock it while i undo the bolt. I was wrong they are just indentations. Is there any way i can lock these off or will i need to take the box to a garahe for them to blast the bolts with an air gun? |
SirAndy |
Jun 21 2017, 01:28 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Put two bolts in the flange and use a bar to hold the flange while you're turning the center bolt.
(IMG:style_emoticons/default/smash.gif) |
mark04usa |
Jun 21 2017, 01:32 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
IIRC the torque on the bolts is about 31 ft lbs, so should come off easily (I was lucky and mine were easily R&R'd). Be sure not to set the seals too deeply or they will fail and leak quickly as mine did...I had to do this job twice!
JFG |
Jun 21 2017, 01:46 PM
Thanks for the info. i wasn't sure about the torque figures so got a bit worried. Nice tip about seal seating, i definitely don't want to do it twice!
Justinp71 |
Jun 22 2017, 12:07 PM
Senior Member Group: Members Posts: 1,595 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I need to redo mine. I plan to knock the seal flush with a piece of wood. Then take a piece of 2" PVC pipe to knock the seal flush with the case.
I had the issue with the seal tearing on install last time, any reason why I can lube up the back of the seal with some trans fluid to help prevent tearing? |
Lo-Fi Version | Time is now: 27th September 2024 - 10:18 AM |
