fuel flow, need a visual |
joeav8tor |
Jun 2 2005, 06:05 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
anybody have a schematic of the fuel system lines...the haynes manual is making my eyes bleed...a picture or schematic of how the fuel flows would help me out...that drive tomorrow is fading away.
Joe |
SLITS |
Jun 2 2005, 06:14 PM
two lines from the tank....one is supply, one is return. Supply line is hooked to the filter in the engine bay then to the "S" (suction) on the pump (believe it is the middle barb).
From the "D" (druck= pressure) barb on the pump a line runs to the fuel rail on the passenger side. From the passenger side fuel rail, a line runs to the driver's side fuel rail. From the driver's side fuel rail, a line runs to the pressure regulator. From the pressure regulator, a line runs to a "T" near the fuel pump (you have to supply the "T". From the pump barb "R" return, a line runs to the "T" From the "T" the line runs back to the tank. Now that said, there are plastic lines that come out of the tunnel that you attach hose to. There are plastic lines that come up thru the engine tray you attach hose to for both supply and return. No pics.....sorry |
redshift |
Jun 2 2005, 06:25 PM
Here you go. It's not right, but it is a picture.
M Attached image(s) |
redshift |
Jun 2 2005, 06:29 PM
Ok, I am lost
Attached image(s) |
joeav8tor |
Jun 2 2005, 06:45 PM
thanks guys, between the vebal, visual, and a picture I took...I think I got it...thank you.
Joe |
Lo-Fi Version | Time is now: 27th September 2024 - 12:47 PM |
