Bushings in Shift Rod Coupling |
DickSteinkamp |
Mar 21 2018, 04:56 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
How do you replace the bushings (#25 in the illustration) in the shift rod coupling (#24)? This is a side shift trans.
(IMG:http://www.914world.com/bbs2/uploads_offsite/345053ca7e80c5ad4275-5ac4a1cffde6c91f8fe01efb688d265e.r54.cf2.rackcdn.com-20876-1521673230.1.gif) Thanks! |
BeatNavy |
Mar 21 2018, 05:11 PM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
You need to drive the pin out (#26 in the picture). That can be a real bear depending on the level of crud on it. A lot of PB Blaster and heat and either a press or a vice, drift, and large cheater bar.
UROpartsman |
Mar 21 2018, 05:12 PM
Member Group: Members Posts: 292 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
This thread might help: http://www.914world.com/bbs2/index.php?showtopic=56765
troth |
Mar 21 2018, 05:22 PM
Member Group: Members Posts: 155 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
I was having some trouble with the pin. I ended up cutting up a soda bottle and filling it with PB blaster. Soaked for 72(!) hours straight. I tried hammering it out once each evening until I finally got it on the third night of soaking. Maybe I was being a little too careful about cracking the weld on the fork of the shift rod, but I really didn’t want to find out.
DickSteinkamp |
Mar 21 2018, 05:39 PM
Thanks all!
The thread posted by UROpartsman is perfect. Should be a sticky. |
Mikey914 |
Mar 21 2018, 10:13 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
here's another and when you need a set I'll beat any price out there by 10%
(If I'n not already lower) http://www.914world.com/bbs2/index.php?sho...mp;hl=shift+rod The parts (and others you may need) can be purchased with to save some real cash. http://www.914world.com/bbs2/index.php?sho...mp;hl=shift+rod Make no mistake URO I will not be undersold. Attached image(s) |
UROpartsman |
Mar 22 2018, 09:33 AM
Make no mistake URO I will not be undersold. (IMG:style_emoticons/default/rolleyes.gif) DickSteinkamp's question was how to replace the bushings, not where to buy them, or who makes them. |
dr914@autoatlanta.com |
Mar 22 2018, 10:27 AM
914 Guru Group: Members Posts: 8,108 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have made the delrin shift coupler bushings for years with the perfectly round hole ever since Porsche modified the original part number to resemble the oval hole of the 356 911 cars and if installed in a 914 caused shifter slop.
Please take not Drew! "we will NOT be undersold!!" (LOL) |
Mikey914 |
Mar 22 2018, 11:09 AM
Today only for all 914World members .01 shifter bushing sets (1 set only each), you pay the shipping (reg mail is the least expensive)
My thinks to all here (I'll also start another thread so all can see). -Mark https://www.shop.914rubber.com/searchquick-submit.sc?keywords=knuckle Get them now! |
bdstone914 |
Mar 23 2018, 08:00 AM
bdstone914 Group: Members Posts: 4,731 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Today only for all 914World members .01 shifter bushing sets (1 set only each), you pay the shipping (reg mail is the least expensive) My thinks to all here (I'll also start another thread so all can see). -Mark https://www.shop.914rubber.com/searchquick-submit.sc?keywords=knuckle Get them now! Free bump. I have tried several bushing out there and most are not good. Got a set from Sierra Madre and they were over size on the pin hole and under size on the OD. Got some through Pelican and they were too tight on the OD and had to be drawn in with a bolt and nut. Porsche elongated to hole but no one likes them. Anxious to try Marks bushings. Have not tried AA or Uro. Seen enough problem with their other parts. |
76-914 |
Mar 23 2018, 08:21 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Mark, I love ya son but................those bronze bushings from pelican are soooooo nice. However at $50 bucks a pop + their usual shipping (HiJack) charge, yours are about %1000 cheaper. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 21st December 2024 - 12:35 PM |
