fuel pipes leaking |
JFG |
May 8 2018, 02:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Again. The joints at the tank where the tails bolt on are leaking again. I've tried allsorts.
What else? |
TravisNeff |
May 8 2018, 02:44 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Do you have the fiber sealing washers on the fittings?
iankarr |
May 8 2018, 07:40 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,512 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Also make sure the brazing surrounding the flanges on the pipes isn’t cracked from over-tightening
Elliot Cannon |
May 8 2018, 08:35 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I think I used Teflon washers.
JFG |
May 8 2018, 11:55 PM
I've tried various materials and combunations. I currently have aluminiun washers in the joint. They sealed at first but now the joint is seeping.
Lo-Fi Version | Time is now: 27th September 2024 - 12:36 PM |
