Need my trans case cleaned, I'm in Portland OR |
gcrotvik |
Jun 1 2018, 09:38 AM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I need to have my trans case cleaned. Can someone recommend a shop in Portland (or the outlying areas) that specializes in cleaning and treating mag cases? I want a professional to do it, as I'd probably make a mistake and damage it in some way.
Thanks, Greg |
mepstein |
Jun 1 2018, 10:39 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If it’s a bare case, find someone with a hot steam pressure washer. Takes 5-10 minutes and gets it clean without chemicals. The steam melts off the tar, undercoating and oil and the pressure gets all the nooks and crannies clean. If you were around me, I’d do it for the cost of a cheap tyvek suit - $10. It makes a bit of a mess.
Then I would just hose it down with Gibbs or ACF-50 |
gcrotvik |
Jun 1 2018, 11:38 AM
If it’s a bare case, find someone with a hot steam pressure washer. Takes 5-10 minutes and gets it clean without chemicals. The steam melts off the tar, undercoating and oil and the pressure gets all the nooks and crannies clean. If you were around me, I’d do it for the cost of a cheap tyvek suit - $10. It makes a bit of a mess. Then I would just hose it down with Gibbs or ACF-50 Hi Mark, It's a NOS case that is clean of grease/dirt/etc. It is NOS though so the magnesium surface has oxidized. There is no pitting so I'd like to remove the oxidation. Some have suggested soda blasting? Will a hot tank clean the oxidation off? I'm going to pull all the studs this weekend and get them ready to be re-plated. Greg Attached image(s) |
mtndawg |
Jun 1 2018, 12:00 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I've soda blasted light oxidation with good success. After soda blasting I've been told that it's a good idea to rinse with vinegar.
cary |
Jun 1 2018, 01:29 PM
Greg, Gordon Ledbetter uses plastic beads to finish the high $$ mag cases.
gcrotvik |
Jun 1 2018, 01:34 PM
Greg, Gordon Ledbetter uses plastic beads to finish the high $$ mag cases. Hi Cary, Thanks for the information. The last time I was in the shop, Jeff mentioned that Gordon wasn't regularly in the shop these days. Is that true? If so, what is the best way to get a hold of him? Thanks, Greg |
mepstein |
Jun 1 2018, 01:40 PM
The place we use to blast our chassis uses plastic media. I bet if you call around you can find someone. It will look great when done.
cary |
Jun 1 2018, 01:43 PM
They bought a place in Arizona. I think he's finally really retiring.
But he was in the shop week ............. I think you'll need to catch him at weak moment. When I get home I'll PM you his contact info. |
bretth |
Jun 1 2018, 01:44 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I believe hot tanking can dissolve magnesium from what I have heard.
Lo-Fi Version | Time is now: 26th September 2024 - 09:53 PM |
