Passenger side, Styrofoam |
cpavlenko |
Mar 2 2019, 02:25 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
mepstein |
Mar 2 2019, 02:27 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It's a stock piece. Looks maybe?
cpavlenko |
Mar 2 2019, 02:28 PM
mepstein |
Mar 2 2019, 02:30 PM
cpavlenko |
Mar 2 2019, 02:34 PM
Tom_T |
Mar 2 2019, 03:57 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Yes. I guess it smooths out the transition. Yea, probably a filler for carpet. Thanks for the reply. Yes, it's part of the pieces added into the passenger side floor as needed to shorten the space when they eliminated the "dog-bone" footrest of the 1970-71 models with the fixed passenger seat. You should have some other filler going across the passenger footwell too. If not, check with 914Rubber, as IIRC the took over the repro footwell piece with a speaker space from 914A&P (James). You can use with or without a speaker in it. Otherwise, source one from a parts car 914. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
cpavlenko |
Mar 2 2019, 07:31 PM
Yes. I guess it smooths out the transition. Yea, probably a filler for carpet. Thanks for the reply. Yes, it's part of the pieces added into the passenger side floor as needed to shorten the space when they eliminated the "dog-bone" footrest of the 1970-71 models with the fixed passenger seat. You should have some other filler going across the passenger footwell too. If not, check with 914Rubber, as IIRC the took over the repro footwell piece with a speaker space from 914A&P (James). You can use with or without a speaker in it. Otherwise, source one from a parts car 914. (IMG:style_emoticons/default/beerchug.gif) Tom /////// My 914 is a 1971? |
cpavlenko |
Mar 2 2019, 07:39 PM
Yes. I guess it smooths out the transition. Yea, probably a filler for carpet. Thanks for the reply. Yes, it's part of the pieces added into the passenger side floor as needed to shorten the space when they eliminated the "dog-bone" footrest of the 1970-71 models with the fixed passenger seat. You should have some other filler going across the passenger footwell too. If not, check with 914Rubber, as IIRC the took over the repro footwell piece with a speaker space from 914A&P (James). You can use with or without a speaker in it. Otherwise, source one from a parts car 914. (IMG:style_emoticons/default/beerchug.gif) Tom /////// My 914 is a 1971? When I go to the shop, I'll take some pics where it goes and post it. |
mepstein |
Mar 2 2019, 07:43 PM
I’m pretty sure the early cars had a smaller piece of foam than the later cars and they also had the dog bone. At least most of my cars are that way.
76-914 |
Mar 4 2019, 09:53 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have the old & new style ones. They're interchangeable. Mark is correct. One is slightly larger than the other. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 10:39 AM |
