Seat belt retractors. |
mb911 |
Aug 29 2019, 03:27 PM
914 Guru Group: Members Posts: 7,161 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I want to remount my seatbelts in my car and since the car was apart when I got it they are fully retracted.. How do I get them to move outward again?
Chi-town |
Aug 29 2019, 04:01 PM
Senior Member Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
bolt the retractor down first, it'll let go then
Garland |
Aug 29 2019, 04:09 PM
Restoration Fanatic Group: Members Posts: 1,370 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
The belt will only release if the retractor is orientated correctly, gravity is required.
mb911 |
Aug 29 2019, 04:10 PM
Oh gotcha. Had no idea . Thanks.
jim_hoyland |
Aug 29 2019, 04:32 PM
Get that VIN ? Group: Members Posts: 9,418 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Some interesting seatbelt info :
https://914electric.wordpress.com/2011/09/2...elt-tightening/ I freed up the belt using their recommendation... (IMG:style_emoticons/default/smile.gif) |
Garland |
Aug 29 2019, 04:45 PM
And easy way to clean them up is in hot soapy water. Lower the whole mechanism into the bucket run it back-and-forth dry thoroughly. Trying to unwind the mechanism, and then reset it is troublesome.
dr914@autoatlanta.com |
Aug 29 2019, 05:13 PM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the cleaning is very important, and then you can pull the belt out all of the way and lubricate the bobbin for smooth operation
And easy way to clean them up is in hot soapy water. Lower the whole mechanism into the bucket run it back-and-forth dry thoroughly. Trying to unwind the mechanism, and then reset it is troublesome. |
mb911 |
Aug 29 2019, 05:48 PM
Gosh do I feel stupid. Thanks to the recommendations from everyone they are out and working. Thank you.
Lo-Fi Version | Time is now: 27th September 2024 - 08:21 AM |
