How best (and inexpensively) connect headers to exhaust? |
Tdskip |
Nov 27 2019, 01:49 PM
Advanced Member Group: Members Posts: 3,697 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Tdskip |
Nov 27 2019, 01:50 PM
Superhawk996 |
Nov 27 2019, 02:05 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
@Tdskip
I apologize I'm in a giddy mood in advance of the holiday. Cheapest way to connect the exhuast is with $1.20 worth of bolts. (IMG:style_emoticons/default/rolleyes.gif) Best way is to have have @mb911 fabricate a beautiful system out of Stainless to your specification. (IMG:style_emoticons/default/lol-2.gif) If you go the muffler shop fab route, who knows what you'll get especially if you can't supply the flanges. I've had great shops that do extraordinary work for dirt cheap at times and other times I can tell it was some new Goober they just hired that day that they turned loose with a torch and a MIG. What ever they do, make sure they provide some sort of support bracket. You don't want the weight of some muffler assembly being suppoted by the headers, they will crack in very short order. See . . . I tried to be helpful. (IMG:style_emoticons/default/laugh.gif) |
mb911 |
Nov 27 2019, 02:41 PM
914 Guru Group: Members Posts: 7,162 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Garland |
Nov 27 2019, 02:44 PM
Restoration Fanatic Group: Members Posts: 1,370 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Looks like the header is exiting exhaust, forward toward the fan housing?
I could say more. |
Superhawk996 |
Nov 27 2019, 02:47 PM
Looks like the header is exiting exhaust, forward toward the fan housing? I could say more. (IMG:style_emoticons/default/WTF.gif) I was too busy being a smat ass to notice that! Is that a bus exhaust header? |
Garland |
Nov 27 2019, 02:49 PM
Looks like the header is exiting exhaust, forward toward the fan housing? I could say more. (IMG:style_emoticons/default/WTF.gif) I was too busy being a smat ass to notice that! Well to be honest that was a rare occurrence gotcha! |
sixnotfour |
Nov 27 2019, 03:06 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
75-76 header...flip em around exit rear... cheeeeper.. Dont break a stud $$$
Rand |
Nov 27 2019, 03:15 PM
Nacho |
Nov 27 2019, 03:20 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
Just bring it to local muffler shop and have them run the pipes? This is a 2.0L engine going into a ā74. Thanks! I'm thinking that performance would be a bit better with the long tube heat exchanger type headers of a 2.0. They are individual runners coming off each exhaust port from the head vs. the 2 into 1 as pictured. That design seems restrictive for the proper exhaust flow exit. |
sixnotfour |
Nov 27 2019, 03:23 PM
oorrrrrr 914 Werke has the heat exchangers for this appp.
Tdskip |
Nov 27 2019, 03:29 PM
Thanks gentlemen ā exhaust optima on 914 is a whole new topic for me, so appreciate the thoughts.
Iām planning on @mb911 for the /6 exhaust, this one I need to be as frugal as non-self defeating on. For education purposes, is it correct to say the issue with these is that you have two cylinders venting into the same pipe in close proximity to each other? |
sixnotfour |
Nov 27 2019, 03:35 PM
depends on ap.. for my m38a1 with a 307 2bbl 8 into one is a low rpm torquer
rhodyguy |
Nov 27 2019, 03:49 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
They are pointing the wrong direction, correct for late HEs. Only thing to make them work is the correct HEs/ducting or fab something up. More stub pipe than header. Cheapest easiest would be a set of early ones with garbage casings (usually about for the price of shipping and a bit for time and gas). More exhaust options this route,
Triaddave |
Nov 29 2019, 02:22 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
Those are the header part of a 75/76 car and they are pointed foreword as they should be to accept the rest of the heat exchangers. You can swap them side to side, they will fit. With the flanges pointed towards the rear, you could have some stup pipes made to the exhaust bracket (stock location and configuration) then just get a 75/76 exhaust to match. Triad does make those. That is what I would do...
Tdskip |
Nov 29 2019, 03:20 PM
Those are the header part of a 75/76 car and they are pointed foreword as they should be to accept the rest of the heat exchangers. You can swap them side to side, they will fit. With the flanges pointed towards the rear, you could have some stup pipes made to the exhaust bracket (stock location and configuration) then just get a 75/76 exhaust to match. Triad does make those. That is what I would do... Very help - thanks! |
barefoot |
Nov 29 2019, 04:30 PM
Senior Member Group: Members Posts: 1,318 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
sixnotfour |
Nov 29 2019, 04:49 PM
Holy Ferrari.....run em Skip (IMG:style_emoticons/default/beerchug.gif)
Tdskip |
Nov 29 2019, 05:15 PM
Lo-Fi Version | Time is now: 27th September 2024 - 11:48 AM |
