Pressure regulator rebuild, Brake |
trojanhorsepower |
Apr 11 2020, 04:26 PM
Senior Member Group: Members Posts: 866 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Hello All,
Hope everyone is doing well. I am trying to rebuilding my pressure regulator. I got the kit from PMB, but it does not have any instructions. I understand that it is pretty intuitive, but I don't know what to do with the included grease. Also what is the point metal bit for? |
rgalla9146 |
Apr 11 2020, 05:26 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hello All, Hope everyone is doing well. I am trying to rebuilding my pressure regulator. I got the kit from PMB, but it does not have any instructions. I understand that it is pretty intuitive, but I don't know what to do with the included grease. Also what is the point metal bit for? The grease is for the piston. The bullet thing is to stretch a seal way more than you'll believe. Make sure you face the seal in the right direction.....take pics as you disassemble. I've done mine but have not installed it yet. We'll see. Attached thumbnail(s) |
Mueller |
Apr 11 2020, 05:27 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Hello All, Hope everyone is doing well. I am trying to rebuilding my pressure regulator. I got the kit from PMB, but it does not have any instructions. I understand that it is pretty intuitive, but I don't know what to do with the included grease. Also what is the point metal bit for? I did this a few weeks ago. A. Grease is for the seals, greatly helps in the install. The type included is brake fluid compatible. B. I believe the cone shaped part goes over the small end of the piston to help with the installation of the small seal. On mine the cone shaped part was too short so it came up short of the larger OD feature. I did not use it. C. I posted a diagram of the regulator, let me find it. |
Mueller |
Apr 11 2020, 05:33 PM
A vise helps, or at least it helped me.
I modified some soft jaws to hold the piston, like a 3rd hand. Oh yea, those funny looking tools are o-ring tools I made in A&P school over 30 years ago. |
trojanhorsepower |
Apr 11 2020, 08:29 PM
Awesome!
Thank you guys. |
914043 |
Apr 14 2020, 10:35 AM
Member Group: Members Posts: 90 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California |
would like to hear from Eric at PMB as to how to use the alum conical devise for seal install, seams to short to be of any help.
Lo-Fi Version | Time is now: 27th September 2024 - 08:53 AM |
