Someone still making a trigger points test jig? |
914ltd |
May 11 2020, 09:25 AM
Member Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
After a long dry spell, I am seeing trigger points problems again. I have many sets to test. Rent me yours? Locate the maker? Thanks, Brad Mayeur |
914Sixer |
May 11 2020, 09:31 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Brad,
Do you a have an old worthless distributor? Just cut it in half so you can mount points. That way you can watch them open and close with a meter. Maybe this will work for you. |
914werke |
May 11 2020, 09:40 AM
"I got blisters on me fingers" Group: Members Posts: 10,546 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Brad do a search on UID = nordfisch @nordfisch
914ltd |
May 11 2020, 01:40 PM
Brad, Do you a have an old worthless distributor? Just cut it in half so you can mount points. That way you can watch them open and close with a meter. Maybe this will work for you. Hi Mark That's way too simple. I tend to lean toward the complicated, ridiculously expensive solutions and expect poor results. (Thanks!) |
Lo-Fi Version | Time is now: 27th September 2024 - 12:02 PM |
