Speedo Cable Availability - Bad batch of Gemo |
Brian Fuerbach |
Jan 20 2021, 03:11 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
I ordered parts from Pelican this week but they did not have the speedo cable I needed available. I read the two Pelican reviews posted for the Gemo cable and both said the part did not fit. Apparently the transmission end is not threaded correctly. I ended up ordering from SMC, well guess what? The cable has reverse threads at the angle gear connection and does not fit. I suspect a bad batch.
Does anyone know of a West coast vendor or member that has good stock? Thanks, Brian |
StratPlayer |
Jan 20 2021, 03:34 PM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Brian Fuerbach |
Jan 20 2021, 04:17 PM
Speedo cable needed. |
mepstein |
Jan 20 2021, 04:50 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Check with your local Porsche dealer.
IronHillRestorations |
Jan 20 2021, 04:55 PM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
A customer of mine got a bad one as well. Sent it back to PP and got one that was fine. Never had the problem before, but like you, it wouldn't thread on the angle drive
Brian Fuerbach |
Jan 20 2021, 08:14 PM
cary |
Jan 20 2021, 09:40 PM
Brian Fuerbach |
Jan 20 2021, 11:07 PM
Thanks Cary, I did not think of them. |
Mikey914 |
Jan 21 2021, 01:00 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I will double check my supply in the morning. Yes I can make these if I need to.
Brian Fuerbach |
Jan 21 2021, 01:56 PM
Update: Auto Atlanta confirmed that three cables they just received have mismatched threads on the angle gear side. Do not buy a Gemo speedo cable without confirming with the seller that the threads are proper.
I had an ebay seller tell me that they no longer have them in stock after I inquired and another that says "I would say, don't buy mine, I don't have time to look. Thanks, Anyway!" (IMG:style_emoticons/default/confused24.gif) |
rudedude |
Jan 21 2021, 08:26 PM
Senior Member Group: Members Posts: 516 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I got a bad one a while ago from one of our venders. He refused to believe that it could be the case. Had to slot the old end to slide it on the cable to attach to speedo drive. Maybe now he will see this and send me a replacement.
Brian Fuerbach |
Jan 21 2021, 10:36 PM
I got a bad one a while ago from one of our venders. He refused to believe that it could be the case. Had to slot the old end to slide it on the cable to attach to speedo drive. Maybe now he will see this and send me a replacement. I ended up making the cable work. I realized that the bad angle gear nut could come off the sheath if I could get the smaller speedo side nut off. I carefully enlarged the hole in the speedo side nut until it cleared the flange. I then slid the bad angle gear nut off and replaced it with the nut from my original cable. I then made a thin split washer out of a shim that captured the speedo nut. Worked like a charm. See the picture. Attached thumbnail(s) |
914Sixer |
Jan 22 2021, 07:11 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NOW I have to go to warehouse and check the Gemo I have.
rudedude |
Jan 22 2021, 07:35 AM
I don't know how to do the qoutes, but I believe for what the parts are costing us that we shouldn't have to figure out a way to make them work when they aren't made properly in the first place. Then when you talk to the seller and they tell you that you don't know what you are doing because the part must be correct. It is nice to see others having the same issues.
Brian Fuerbach |
Jan 22 2021, 11:25 AM
I don't know how to do the qoutes, but I believe for what the parts are costing us that we shouldn't have to figure out a way to make them work when they aren't made properly in the first place. Then when you talk to the seller and they tell you that you don't know what you are doing because the part must be correct. It is nice to see others having the same issues. I agree that the parts should always be correct but I thought $50 for a speedo cable was extremely reasonable. The clutch cable was only $16! I pay more for a 12 pack of my favorite beer. (IMG:style_emoticons/default/beerchug.gif) |
914Sixer |
Jan 24 2021, 07:57 AM
Well, I guess I got lucky. My new GEMO cable fit on both ends.
Brian Fuerbach |
Jan 24 2021, 01:20 PM
Lo-Fi Version | Time is now: 27th September 2024 - 01:20 PM |
