FS: NOS Bosch Closeout, Voltage Relay, Condensor, Cylinder Head Temp Sender |
914Sixer |
Jan 24 2021, 05:50 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Closeout on NOS Bosch items:
Electronic voltage regulator $99 shipped (list price $357) Distributor Condenser $24each shipped (Not like the new ones Made in Turkey that are too short) Rare NLA 003 Cylinder head temperature senders $49 each shipped.(Part superceded by 012 sender. Can be used to enrich cold running engines.) Attached image(s) |
914Sixer |
Jan 24 2021, 06:53 PM
One 003 head temp sender sold.
Superhawk996 |
Jan 24 2021, 06:56 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I'll take the Condenser please. Paypal forthcoming.
second wind |
Jan 25 2021, 12:11 AM
Senior Member Group: Members Posts: 860 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
I would like the other cylinder head temp sensor if it is good for a '73 2.0. Thank you very much.
gg |
914Sixer |
Jan 25 2021, 07:27 AM
Greg,
This sensor is not for you. You need 017. |
MM1 |
Jan 25 2021, 11:51 AM
914 obsession continues Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Mark,
I'll take the distributor condenser, please. |
second wind |
Jan 25 2021, 11:55 AM
StarBear |
Jan 25 2021, 12:03 PM
Advanced Member Group: Members Posts: 2,054 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
I'll take the third (last) condenser. Please confirm if still available; thanks!
[Just to make sure, this is the one with the square plastic insert piece? Can't see the part number too clearly] |
914Sixer |
Jan 25 2021, 12:23 PM
StarBear,
It is the round hole for inside with square on the outside for retaining clip. It is correct for all factory distributors with D-jet fuel injection |
StarBear |
Jan 25 2021, 12:38 PM
914Sixer |
Jan 25 2021, 01:20 PM
Not for you.
StarBear |
Jan 25 2021, 01:33 PM
Ok! Thanks. (IMG:style_emoticons/default/biggrin.gif)
mxkinn01 |
Jan 25 2021, 03:18 PM
Member Group: Members Posts: 245 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
IIRC the 003 temp sensor is for the 1.7 correct. If it is I'll take the last one.
914Sixer |
Jan 25 2021, 04:36 PM
Yes the 003 is correct for the 1.7
mxkinn01 |
Jan 25 2021, 06:05 PM
PM sent
Lo-Fi Version | Time is now: 27th September 2024 - 12:37 PM |
