914 transmission corvair engine, will these work together ????? how? |
goobstine |
Mar 27 2021, 02:50 AM
Newbie Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
will the monza corsa corvair 6 cyl air cooled engine work with a stock 914 transmission. ( not mount it is already mounted with adapter plate ) it is my understanding corvair engine rotates counter clockwise. How could this possibly operate with a stock 914 transmission? I have the transmission out of the car is there any way to check the rotation of the trans gears and things to see if i am getting the correct rotation out of my trans in a reverse fashion for the corvair counter clockwise action i will be receiving.
ClayPerrine |
Mar 27 2021, 04:54 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
will the monza corsa corvair 6 cyl air cooled engine work with a stock 914 transmission. ( not mount it is already mounted with adapter plate ) it is my understanding corvair engine rotates counter clockwise. How could this possibly operate with a stock 914 transmission? I have the transmission out of the car is there any way to check the rotation of the trans gears and things to see if i am getting the correct rotation out of my trans in a reverse fashion for the corvair counter clockwise action i will be receiving. any help would be appreciated. There are companies that make (made) reverse rotation camshafts for Corvair engines. That is the proper way to put a Corvair engine against a 914 transmission. Others will tell you to just flip the ring and pinion in the transmission. But that is a bad idea. The 901 transmission uses helical cut gears inside it to reduce noise. Whenever helical cut gears are used, the "climb" against each other, putting thrust loads on the shafts. That load is transferred to the transmission case. If you reverse the rotation of the input shaft, you will reverse the "climb" of the gears. And that reverses the thrust loads on the transmission case. The engineers that designed the transmission did not provide thrust bearings for the reversed load. So now the transmission is running thrust loads against the magnesium case without the proper thrust bearings. This drastically shortens the life of the transmission. I hope that helps. Clay |
Mark Henry |
Mar 27 2021, 05:33 AM
If I was looking to do a different engine it would be a V8 or subi.
Personally with the 914 values going up I'd stick to the T4. |
goobstine |
Mar 28 2021, 03:58 AM
will the monza corsa corvair 6 cyl air cooled engine work with a stock 914 transmission. ( not mount it is already mounted with adapter plate ) it is my understanding corvair engine rotates counter clockwise. How could this possibly operate with a stock 914 transmission? I have the transmission out of the car is there any way to check the rotation of the trans gears and things to see if i am getting the correct rotation out of my trans in a reverse fashion for the corvair counter clockwise action i will be receiving. any help would be appreciated. There are companies that make (made) reverse rotation camshafts for Corvair engines. That is the proper way to put a Corvair engine against a 914 transmission. Others will tell you to just flip the ring and pinion in the transmission. But that is a bad idea. The 901 transmission uses helical cut gears inside it to reduce noise. Whenever helical cut gears are used, the "climb" against each other, putting thrust loads on the shafts. That load is transferred to the transmission case. If you reverse the rotation of the input shaft, you will reverse the "climb" of the gears. And that reverses the thrust loads on the transmission case. The engineers that designed the transmission did not provide thrust bearings for the reversed load. So now the transmission is running thrust loads against the magnesium case without the proper thrust bearings. This drastically shortens the life of the transmission. I hope that helps. Clay Thank you |
goobstine |
Mar 28 2021, 04:25 AM
rgalla9146 |
Mar 28 2021, 05:55 AM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If I was looking to do a different engine it would be a V8 or subi. Personally with the 914 values going up I'd stick to the T4. I do not need or want your advise or comments ever ! please stay away from my posts. thank you This may not end well. |
Mark Henry |
Mar 28 2021, 07:25 AM
If I was looking to do a different engine it would be a V8 or subi. Personally with the 914 values going up I'd stick to the T4. I do not need or want your advise or comments ever ! please stay away from my posts. thank you This may not end well. I have no idea who goober is or what's his damage, but really I don't care. |
larryM |
Mar 28 2021, 11:31 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
rhodyguy |
Mar 28 2021, 11:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
OH MY!
KELTY360 |
Mar 28 2021, 11:44 AM
914 Neferati Group: Members Posts: 5,081 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
If I was looking to do a different engine it would be a V8 or subi. Personally with the 914 values going up I'd stick to the T4. I do not need or want your advise or comments ever ! please stay away from my posts. thank you What’s your problem newbie? That’s not how we treat people around here. |
rhodyguy |
Mar 28 2021, 11:53 AM
Just put Mark on ignore if his comments are unwelcome. That's what we are told to do. Admins set appropriate content. Enjoy your covair engine build. Usually the parts required go for a short song due to the stalled project.
sixnotfour |
Mar 28 2021, 12:28 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Back in the Day ...Allot of ring gears got flipped...... 914 trans are Cheep..Go till She Blows...
Chances are itll drop a valve seat ,,,before the trans fails... |
gandalf_025 |
Mar 28 2021, 02:14 PM
Senior Member Group: Members Posts: 1,471 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I’m pretty sure if you flip the differential on a 914 transmission and
Change out the shift rods and end cover you get a 911 transmission.. Think it will work fine with a flipped diff. Corvair engine would need a reverse cam and maybe a reverse distributor drive gear set and they make a kit to help the backwards fan belt stay on.. If you are going to use a Corvair engine, make sure the valve seats are tight. Those are a known weakness of those heads. |
Front yard mechanic |
Mar 28 2021, 02:24 PM
Senior Member Group: Members Posts: 1,205 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Save the corvair (IMG:style_emoticons/default/barf.gif) it's not worthy in a 914 (IMG:style_emoticons/default/pray.gif)
clarkcou |
Mar 28 2021, 09:11 PM
Member Group: Members Posts: 115 Joined: 17-October 03 From: Peoria, Arizona Member No.: 1,257 Region Association: Southwest Region |
If I was looking to do a different engine it would be a V8 or subi. Personally with the 914 values going up I'd stick to the T4. I do not need or want your advise or comments ever ! please stay away from my posts. thank you RUDE |
goobstine |
Mar 29 2021, 09:18 AM
I’m pretty sure if you flip the differential on a 914 transmission and Change out the shift rods and end cover you get a 911 transmission.. Think it will work fine with a flipped diff. Corvair engine would need a reverse cam and maybe a reverse distributor drive gear set and they make a kit to help the backwards fan belt stay on.. If you are going to use a Corvair engine, make sure the valve seats are tight. Those are a known weakness of those heads. thank you |
goobstine |
Mar 29 2021, 09:21 AM
goobstine |
Mar 29 2021, 09:23 AM
goobstine |
Mar 29 2021, 09:30 AM
[quote name='clarkcou' post='2903719' date='Mar 28 2021, 10:11 PM']
[quote name='goobstine' post='2903436' date='Mar 28 2021, 03:25 AM'] [quote name='Mark Henry' post='2903166' date='Mar 27 2021, 06:33 AM'] If I was looking to do a different engine it would be a V8 or subi. Personally with the 914 values going up I'd stick to the T4. [/quote [/quote] [/quote] |
rhodyguy |
Mar 29 2021, 09:33 AM
Well? You're watching. Not OP.
Lo-Fi Version | Time is now: 27th September 2024 - 11:16 AM |
